I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
