Manufacture 8/2010
It should be due to its Y-Sustain and drive boards. Just enter this site named 'Electro-help'. You can see so many problems that can occur with Panasonic plasma TVs and description related faulty boards . Try this link and select the site. Pull up older posts there.
SOURCE: Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
SOURCE: My Toshiba 42" has 3 black lines on right half of
panel its dying :( sorry better get new one :((( you still can try with the old one some time the cables that control the the rows get unglued you can try heating them and reg glue them
Good luck
SOURCE: I have a Viera 42 inch plasma tv (model
the problem is the panel is going bad. usually not economical to repair. repair usually runs as much as a new one.
These lines are horizontal and about 1 to 2 inches wide.
