you have a defrost problem,bad defrost heater,thermostat,sensor or computer board,your gonna need a meter to see what's bad,go here
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GSH25JSTASS/0432/0165000/G0604755/00003?blt=06&prst=0&shdMod=GSH25JSTASSthis is the parts that are behind the back inside freezer wall,look at 230,240 and 243 and on the outside back of the machine is the computer board part number wr55x10942,hopefully it won't be the board,shut down the machine and remove the back inside wall of the freezer,then go in the back and remove the cover of the mother board,you'll see a metal panel it's behind it,look at the bottom of the board,you'll see a gray plug with three connectors that it's plugged onto,you'll need a jumper wire with alligator clips on the ends,clip it on j9 and j11,this is the middle and the metal to the right in the gray plug,this will turn on the heater in the freezer,,plug the machine back in,if the heater comes on you have a bad board and change out the sensor if it has the black ring on it,no matter what you have to change the sensor if it has black on it,if it doesn't come on then check the thermostat and the heater,unplug the heater and check it for continuity,also look at the heater,if it looks black inside the glass change it out and change out the t-stat,if the heater is good check the t-stat,part number 240 in the picture,also you can cut the two wires going to the t-stat,connect them so you bypass the t-stat and jump out the board again,if the heater comes on the t-stat is bad and this is the most common part that goes,also if there's a white plastic ring around the top of the t-stat and it's popped up on one side it's bad,water got inside of it,froze up and pops the top off.here's a picture of the board and how to jump it out
http://www.flickr.com/photos/zenzoidman/4482598198/sizes/o/in/photostream/j9 and j11.and here's another picture that might help you http://fixitnow.com/wp/2008/11/04/how-to-test-the-defrost-system-in-a-ge-arctica-or-profile-refrigerator/
you can leave the heater on to help you melt out the ice and with a hair dryer melt out all the ice on the coil,also if you need time to get the parts and stuff if you remove the back inside wall of the freezer and melt out all the ice on the coil your fridge will run for 10 to 12 days and then it will freeze up again but your food will stay good and then hopefully you can have what you need to fix it.hope this helps and good luck.
If I was using the services of someone else I wouldn't have bothered to post the question here!
