Push the little black button at the front bottom right on the bowl and lift the bowl front and pull it towards you to remove. pull the auger off and the shaft seal is the opaque cup-shaped seal between the auger and the barrel on the shaft. lube new seal with food safe lubricant (i.e. superlube), lube the large rear bowl seal as well and reassemble.
