SOURCE: Emerson TV EWT2721 27"
Did the TV get pink with the wavy lines all at once, or did it start out gradual? If all of a sudden, then a defective part on the CRT control board or the picture tube itself could be going bad along with some components in the video section of the set. Probably not a cheap and easy fix I'm afraid.
SOURCE: Emerson EWT2721 will this TV support a Sony DVD recorder?
If you do not get result you can purchase one video rf converter. Rf converter contains one videoinput in yellow colourand two audio in red and white colour and one cable connector as outout. Connect dvd output to this converter and tune the program in whichplace you receive dvd signal. good luck
SOURCE: color are very off on my emerson EWT2721
Hey just go to menu- picture, and increase your contrast, brightness, and/or tint.
SOURCE: EMERSON TV MODEL EWT2721
unplug your tv and check the volts in primary capacitor .if it will not discharge the regulator IC is bad .
SOURCE: TV HAS SOUND BUT NO PICTURE
replace the H.O.T horiz. Driver Transistor.
comen problem with this set.
