Plugged into wall charger and nothing. Plug into notebook and when tablet is on it says it is not charging. However, when tablet is plugged into laptop and tablet turned off, it slowly charges and it says I have more battery life when I turn it back on. However tablet says it still isn't charging.
SOURCE: THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
Testimonial: "thankyou"
SOURCE: My ASUS R1F-K049E Tablet does not have sound.
Reinstall your sound driver. If you do not have the CD that came with the motherboard, then you can downlooad the sound driver from Asus.
Go to the following link and type in R1F in the box (top left corner) where it reads "Input model to search for" Next box, select "All" it will ask for your operating system, and then give you the drivers (including audio)
http://support.asus.com/download/download.aspx
SOURCE: How can I reboot My Asus R1F tablet Pc because it
HI
which windows your using same disk with reboot your system with new instalation of windows
SOURCE: Hello, how much would it
That depends on your warranty and what sections of it are damaged. I would contact a certified repair facility, like Best Buy or Microcenter. They will be willing to give you an estimate up front.
SOURCE: I need a user manual for an Asus Transformer
The link for your transformer is here:
http://dlcdnet.asus.com/pub/ASUS/EeePAD/TF101/TF101_Full_0418d.pdf
