2004 BMW R 1150 RT (ABS) Logo
Posted on Nov 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loud Intermittent Droaning Noise
I was riding my 04' RT1150 yesterday & heard a loud droaning/whining noise when I accelerated over 5,000 rpm, I coasted to a stop downshifting still hearing the noise. When I came to a stop the noise went away. I set off again & intentially reved high over a few gear changes and the noise cam back, again coasting to a stop with the clutch in & again when I came to a stop the noise went away. The noise does not increase with the revs & does not seem to have any effect on the motor. I rode for another hour or so & when entering an on ramp & accelerating hard the noise came back & I noticed the speedo wavering up at 110-120 mph whilst going around 80mph. Again the noise went away coming to a stop at the off ramp. I assumed this was happening in the higher revs until I went over a rail crossing at 25mph & the noise came back again, then at a stop light went away again. Can you please help with any ideas as to what this problem is?
  • 2 more comments
  • tmwilkinson2 Nov 30, 2008
    No the noise does not go away when the clutch is in, it does not sound like a lubrication issue. I was wondering if it has anything to do with the alternator due to the speedo going haywire! and it sounds like it is coming from under the tank area. Thanks for your reply.
  • tmwilkinson2 Dec 08, 2008
    Thanks for your reply, I read the same article. Paul Glaves had kindly replied & suggested the speedo cable. The rear drive is all ok.
  • tmwilkinson2 Dec 10, 2008
    Thanks for your help, looks like this is fixed.
  • Anonymous May 11, 2010
    Can you please tell me if the noise seems to go away when the clutch is in? There is a bearing in the clutch mechanism that can possibly make this noise. Is the noise a sort of screeching, growling noise like perhaps no lubrication somewhere?
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Dec 08, 2008
Anonymous
Expert
Level 2:
Answers
51
Questions
0
Helped
20933
Points
138
Rear axle to ring gear side bearing is loose due to weak preload. might be able to locktight is its not to late. was in bmwmoa memeber mag this month december08
  • Anonymous Dec 09, 2008
    so lube the cable. why leave this help message open for others to answer.
Loud whining noise especially on exceleration in 2010 Mazda Tribute
A loud whining noise on acceleration in a 2010 Mazda Tribute could be a sign of a few different issues. Here are some potential causes:
  1. Power steering pump: A whining noise can be an indication of a failing power steering pump. The noise may increase when the steering wheel is turned.
  2. Alternator: If the whining noise increases with engine speed, the alternator may be failing. This is because the alternator is responsible for charging the battery and powering the car's electrical system.
  3. Transmission: A whining noise during acceleration could also be a sign of transmission issues, such as low transmission fluid levels, worn bearings, or a damaged gear.
  4. Differential: A whining noise that increases with speed could also be a sign of a failing differential. This is the part of the car that transfers power from the engine to the wheels.
It's important to have a professional mechanic diagnose and fix the issue to prevent further damage to your vehicle.
Nissan navara D40 making winding/whining noise when over 1500rpm
turbos normal make a whining noise under load noise may be present more then before if you have changed anything on the intake side sometimes it can be as little as a lest restricted air filter other cause is lose piping but some power loss would be noticeable if this was the cause
hope this helps good luck
Loud whining noise in mitsubishi magna 1991 auto 4 cylinder
The engine will have to be removed and inspected, to find out what has happened. Big expense, may need replacement engine.
2answers
High pitched whine while accelerating
remove the belt and start the engine ..IF THE NOISE disappear it might be idler bearings that driven by belt but if the noise still there check the pcv valve..
LG LDF6810ST whine noise
-After paying an LG serviceman for a home visit, I told to refer to the manual-and there in small print-USE ONLY POWDER CLEANER. Gel and liquids make too much bubbles(thus air) in the hose producing the noise. It will take several washes-but the noise will go away!
I have a 2004 honda civic and it makes a droaning noise when i change gears, coudl this be an internal gearbox fault? i also have a constant screaching noise when driving when i slighly move the steering...
Pilot bearing or a throw bearing is what makes the noise while shifting gears and as for the steering noise, you either have low steering fluid or the steering pump belt is loose.
2answers
Whining noise while accelerating in 1st gear
Check the idler and tensioner pullys for your serpentine belt. I suspect the whining noise heard earlier was due to the fact one was getting a bit stiff or rough turning. When you gave it that extra fuel, the sudden load may have finished it off. Sometimes they lock up, and sometimes they fall apart. Check those items first.
2helpful
4answers
Loud accelerating whining
It is the bearing in the idler pully. about $35 and 30 minutes of work and its fixed.
Top BMW Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
xxxxxx xxx
Are you a BMW Expert? Answer questions, earn points and help others
