Eletric won't roll up or down. makes clicking noise.
The clicking tells me that the elevator motor is getting power. In my experience, these motors brushes wear out over time, this makes them weaker n slower to the point where they just stop working. You can get a replacement for about 40 bucks.
Before you go and get a replacement elevator motor, using utility gloves, remove old motor. Do this by holding the glass up using clear or duck tape if the window is rolled up, if the window is rolled down, insert a towel or a rag in one of the openings the bottom of the door then carefully remove the elevator motor and seat the glass on the towel, test it's funcionality while still plugged in. Also inspect the elevator hardware to make sure nothing is bent or broken, specially the fastener that holds the window glass to the elevator rail.
I hope this will help you fix your problem.
Good luck
