When i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables but i get the same (CONTINUOUS BEEPS) with no display.. HELP!!!!! Details
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used. Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card. Another fault would be that the battery is very low on charge and won't accept any charge. BAD Battery. hope it helps
SOURCE: Continuous short beeping after RAM upgrade
Try the old ram back in if it works you have the wrong ram
ram comes in many shapes and flavours
ddr ddr2 etc
SOURCE: no boot, got continuous beeps at first, reset my 'savage2000' VGA card
The solution may be to locate the JBAT1 terminal and move jumper from pins 1-2 to pins 2-3 for a few seconds and back again. Turn on pc and then hopefully you can access the bios to set the time and date and save settings then re start.
SOURCE: gigabyte k8m800-8237 won't boot with 2nd gig ram installed.
Could have been dusty. Find a copy of Memtest and run it to check things out. Errors could mean a bad stick or bad slot.
SOURCE: Problem with the Gigabyte GA-EP43-UD3L
Trying to help you, please clarify me if the beeps are short or long ones, or some (how many) shor followed by some (how many) long ones. Don't worry, leaving the computer at "beeping mode" won't hurt it. Sorry for the details but these kind of codes identify if it's a motherboard, or CPU, or memory error.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
