20 Most Recent
Gigabyte GA-8LD533 Motherboard Questions & Answers
Motherboard is on but no display
If you have onboard graphics, it might be faulty. Try a graphics card in the machine. If that does not work re seat the cpu. (Take it out of the slot and blow on the pins and put it back) If this still does not work you might have a dead motherboard.
10/22/2013 5:26:20 PM •
Gigabyte...
Answered
on Oct 22, 2013
Please shutdown and plug realtek pcie card to complete the installation
I used the main Gigabyte G31m version 1.1. and get the same error. If I use latest version for network adapter driver (realtex 8139, version: 5.703 (8/28/2008)), it will not work. Then, I change use driver with version: (realtex 8139, version: 5.635 (9/23/2005)), it works well! It seems the driver with version:5.703 (8/28/2008) get another error.
7/23/2013 3:28:29 PM •
Gigabyte...
Answered
on Jul 23, 2013
Unable to install LAN driver, response is Please shut down and plug PCIE Card
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
hope this helps
10/21/2012 6:37:50 PM •
Gigabyte...
Answered
on Oct 21, 2012
I want gigabyte ga-8ld533 vga
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers if your computer came with a motherboard disc the drivers could be on it hope this helps http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html
4/12/2011 9:31:32 PM •
Gigabyte...
Answered
on Apr 12, 2011
In my cpu automatically restart.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
12/18/2010 1:26:09 PM •
Gigabyte...
Answered
on Dec 18, 2010
