Hey, I have a heating problem with my Francis Francis x 1. When i turn it on, the thermometer only show that it heats to about 40 degree and therefore the temperature light is always on... What is wrong with my Francis?
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
SOURCE: Francis Francis X1
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
SOURCE: Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
SOURCE: Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
SOURCE: Boiler gets too hot
Hi there, as far as im aware there is no power board on a Francis Francis X1 and it sounds like one of the thermostats that sits on top of the boiler has gone. Now if you still require assistance please get in touch with myself (David) at [email protected] and i can try to order on in for you or if your not sure i am a domestic coffee machine engineer and have machines sent to me daily from all over the UK and i could fix it for you. Our mother website is www.theespressoshop.co.uk and you can get all the details on there by clicking on the Domestic Repairs on the list on the left hand side. Any probs please get in touch at email address above.
All the best
David
The Domestic Coffee Service
