SOURCE: Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just
might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be
purchased; call the Maytag Customer eXperience Center toll-free at
1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
SOURCE: Maytag Quiet Series 300 smells broken door latch and lower rack
I have had the same problem and there is a simple fix.
The problem in my case was the floating water sensor was stuck and gummed up with grease.
On the bottom of the dishwasher, in the front right corner there is a round doughnut-looking thing. This is the water level sensor. It is open on the bottom, and grease collects there.
When this happens, the air pocket is too small, and the float won't float. then the dishwasher overflows. To clean it: just reach under with your finger, and scoop out the grease.
Sometimes, after doing this, the float then gets stuck in the "up" position. When this happens, the dishwasher completely drains, and the heater element for the dishwasher is exposed, and food cooks onto it, and that is where the smell is coming from.
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
SOURCE: My Maytag dishwaher is three years old. It will
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MDBH945AWW&siteCd=MT_EN_US&userType=Servicer
Above is your link for your manuals, use these along with the DIY self help repair website below, to troubleshoot and hopefully repair the problem.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Now this fix below may not work, but it is always worth a try, if it fits the criteria.
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
