Hello. I have a maxim jumbo remote control but cant seem to find the code to work the sanyo tv/dvd. I can get the tv functions but not the dvd. Any idea what code to use?
Download the user manual to your remote from net. Clcik here to download it. It has all the details.
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
SOURCE: innovage jumbo remote control code for emerson tv/vcr combo
Press code search till light comes on, press device once, press on/off button once and aim at device, when the device turns off, press enter to store code.
To find out the code of the device:
Press code search till light turns on, press device, press code search once, then go through 0-9-when the light blinks first, that is your first number, repeat numbers to get second and third.
SOURCE: Living Solutions Jumbo Remote
for code retrieval:
press and hold "code search" until led lights up solid red.
press the device button (TV for tv, DVD for dvd player, etc.)
press each of the buttons 0-9 untill the light blinks. that means you have the 1st number of the 3 digit code.
repeat to find the 2nd and 3rd.
After you find the 3rd digit, the led will turn off.
Now you have the code!
So, what you do is:
turn on the device you want to program.
aim the remote and hold code search until light remains solid red
press device button
enter the code, led should turn off
after that, press the on/off key.
SOURCE: dmtech remote control programming codes
I have been looking for the same codes myself and all I have found is:
0157
0159
0335
1994
2024
2031
0067
0312
0910
0208
0586
hope one of these work for you.
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Thank you all for your replies. I noticed that you are only giving 3 digits however the remote needs 4 digits? Any other help is totally appreciated.
