Camera shuts off by itself 2-3 seconds after it's turned on, even with new batteries.
SOURCE: My Olympus FE-310 has battery problems!
I have the same model and I sort of took a page out of Solution #2.
I don't have electronic technician experience so I took one main insight: The Poor Design of the Conduction in the bottom cover.
Here's what I did: I took some Copper Wire (mine came from the wire you use to hang paintings) and some Aluminum Foil.
Next I wrapped the Copper Wire with the Foil. The piece was roughly slightly bigger than 1/2 of a Postage Stamp.
Then I inserted this metal square over the batteries and closed the cover.
I found that I could take more shots without the camera saying Battery Empty.
See if this works. So far it's touchy but it's been taking more photos than before.
SOURCE: my camera keeps turning off when i try to take a picture even whe
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
To clarify this problem a little bit. When the camera is turned on, the zoom lens opens up and then the camera shuts off, leaving the lens in
Sorry about the last post. Anyway the camera shuts off, leaving the lens open. All this take about three seconds. By the way, the batteries aren't rechargeable.
