Hi, my imac video display for my projector at school doesn't work. It works on other imacs using the same projector and dvi to vga adapter bought at apple. But if I push the adapter very hard against the port on the imac, it will work. It started to go intermittently and I thought it was the cable but it is the port on the imac. I have tried blowing out the port in the hope it was just dirty and can't see anything visibly wrong with it. My guess is a connection inside broke and pressing it makes a temporary connection. It is way too expensive to fix so I was wondering if there was any diy idea someone had to get it to make the connection without pressing the adapter hard into the port... some kind of clamp, or carefully placed fastener/screw to draw the port in so it makes the connection reliably? Or less likely, opening it up and actually being able to see and solder the connection without it being a monumental disassembly? Any "McGyver" creative solutions anyone know of? Thanks in advance.
SOURCE: Replacing the hard drive on a imac G5 first generation
If you want a 300GB drive..Its works great and has got great reviews
except 1 or 2 bad ones. You will get the instruction manual along with
the drive. Click on the link below to get it.
http://reviews.pricegrabber.com/hard-drives/m/22955782/
Let me know if there is something else you want to ask.
Regards,
Sai.
http://www.dtgeeks.com/index.php/features/tutorialview/imac_g5_hard_drive_replacement/
the above link wont let u keep on searching for u information but will directly get u the information on how to replace ur hard drive n wat type of hard drive will support ur machine.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
SOURCE: iMac G5 not connecting to Internet sometimes
hi,
Please follow the steps given at the below mentioned link to resolve the issue:-
http://forum.insanelymac.com/index.php?showtopic=25477
SOURCE: Apple iMac 24" Screen issue
you are not alone. its not that hard to clean. really you need the cloth that came with the screen...most people throw it out. and all you do is dab it with a bit of water and gently massage the screen. and it looks as good as new. if you dont still have the cloth use a very silky delicate piece of cloth. if it is underneath the screen (very unlikely) take it back to the shop you baught it for and if it is an apple store then they will most probably clean it for free.
also do the stains look like the are on the inside or outside? and, do they move at all?
if you took a picture of your screen and posted it on here. i will be able to give you a better idea on how to.. fix ya
SOURCE: Internet connection failed
please check the ip configuration using system preferences in network option if its set to automatic or manual if automatic check the cable betwin your system and the network hub switch or wall socket is fine try also using another cable ...
if the status in your left hand side shows green that means cable is fine if have and ip address and is set to manual please check with your network administrator or it guys to check for proper ip address and gateway address..
there is like very rare chance for the network card in the system to go faulty afyter its mac
thanks and regards
thanksan nd
mos
