SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
SOURCE: freehander leaks at shower heads
Hi
Thank you for your query
If you just grab the showerhead with one hand and then unscrew anticlockwise the pipe underneath it should just screw off, once this has been done simply replace the O ring and rescrew
I hope this has been useful
