SOURCE: miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
SOURCE: miele coffee maker cva 4070
Miele models CVA4070 and CVA4075 have a small, removable pastic part in the shape of a "W" or "M" in the chute of the brew unit. If this plastic part is inserted in the shape of an "M", fault 73 is displayed. Replacing the part in the shape of a "W" fixed my fault message.
SOURCE: Miele CVA4085 coffee machine
no water in tank or water valve close thanks for using fixya pierre
SOURCE: how do i clean my miele coffee system cva 4070?
I have a cva4075 so this may not be exactly the same, but on the 4075 you open the front of the machine and pull out the left hand plastic container on the top. Underneath on the right hand side you will see a small flap. On the bottom side of the flap is a red triangle sign. That flap is the top of the funnel for the ground coffee. You drop the cleaning tablet into this funnel.
SOURCE: My Miele CVA 2660 built
Hi Robin,
I had this problem a year ago. Two things to check:
1. Does the water tank go all the way down so that the small notch at the back of the tank fits into the floor of the machine?
2. Any dirt at the water tank outlet?
Besides these two issues, I would say that it is very likely that the problem is that the valve of the water tank needs to be replaced. This will especially happen if the machine has been lefter without water in the tank for some time.
Good luck.
