Suddenly stopped working on the wireless system, but can get on the internet hard wired. Cannot communicate with the wireless printers either. The router is a Belkin DB750, about 3 feet away from the Dell. A companion PC (Lenovo) using the same router can get on to the internet. I replaced the wireless adapter on the PC, still no luck. It's in fact the same wireless adapter on the companion Lenovo. The Dell is showing a strong wireless signal on the desktop.
SOURCE: Dell Dimension 2400 PC Desktop - Can't connect to internet
The NIC (network interface card) is integrated into the motherboard of the 2400 computer. Most likely that circuit is bad. To fix it you’ll have to replace the motherboard or purchase a NIC card and install it into one of the PCI slots on the motherboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: Ineed to reset network adapter each time I turn on wired desktop
You should check to see if there is a router firmware update and also one for your network adapter. You can use Dell's support website for the adapter
SOURCE: dell dimension 2400, wireless internet
Hi Whitney,
I was able to locate manual and a troubleshooting guide.
Summary: Your modem only supports 802.11b standard, which limits the
throughput to max. 11Mbps (compare to 802.11g = 54Mbps, 802.11n = 108
Mbps). In other words: your connection is only about 10% of the speed
compared to a wired connection via Ethernet cable (100 Mbps). So - if
you can - you should try to use a wired instead of a wireless
connection, but you have to decide what makes is more important to you:
having no cable and you can be away from the modem or the connection
speed.
This also means - and that is in regards to APremkumar's solution -
that you can skip all 802.11n adapters (this would just be a waste of
money). Since you will not find an adapter that only connects to a
class b network, look for something like "802.11b/g".
An example page is here.
You can choose between an internal (PCI card) or external (USB adapter)
solution. Both are ok and the decision depends on the availablity of a
free USB port on your Dell and your comfort of opening the computer
case or not. (You can always come back here and ask for help;-)
If you have any more questions, please let me know - I'm happy to help!
SOURCE: I have a Dell Dimension 3000 desktop, around 5-6
First, try uninstalling then reinstalling the ethernet device. If that fails,try replacing it. Ethernet cards can be found for around $25.
SOURCE: no internet connectn for desktop but wireless works with laptop.
If your running xp, make sure the netowrk card is not disabled, make sure you rnot using a cross over cable. use the cable you got with the routers. Try reinstalling the network card, goto dell support andenter you model to get the drivers.
1 thing to check. goto start ,control panel.
double click on netowrk conections.
right click on the main conection witch is the card in your pc, goto properties. andin the list internet protocol (tcp/ip) click this. and pres properties.
make sure in here obtain ip addres is automatically. and obtain dns is auto too.
Try this let me know how you get on.
Testimonial: "Thanks! Your info helped me dig a bit deeper into the problem. Hopefully will find a solution soon."
