I keep getting this message when trying to install my Neat Receipts mobile scanner: After I accept the Microsoft agreement, it then goes to the next screen, which says: "An error occurred while installing system components for Neat. Setup cannot continue until all system components have successfully installed." Then when I click on details it says: Setup has detected that the file 'C:\Users\(MY COMPUTER NAME)-O~1\AppData\Local\Temp\VSDDB5F.tmp\SQL Server Compact Edition\SSCERuntime-ENU-x64.msi' has changed since it was initially published. See the setup log file located at 'C:\Users\(MY COMPUTER NAME~1\AppData\Local\Temp\VSDDB5F.tmp\install.log' for more information. How do I fix this?
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
SOURCE: Dear Sir, I can't calibrate my
You might want to soft reboot your scanner by pressing and holding the power button for 30 so that the system will be refreshed.
Thanks.
