Polaroid T1234 Digital Camera Logo
Posted on Feb 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i change image mode to video mode? - Polaroid T1234 Digital Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Polaroid Master 102,366 Answers
  • Posted on Feb 29, 2012
Polaroid Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444583
Points
622693
From the Record mode menu, select Movie.
For full details, see the "Recording Movies" section beginning on page 52 of the manual.
1helpful
When I take a close-up video with my canon sd1000 camera, I get a blurry image. When I take a still picture under the same conditions, it comes out nicely in focus. What am I doing wrong?
blurry can be due to out of focus or camera shake are the most common if you are in video mode try turning off Auto focus and using manual or the other way around , next if the image is blurry while in close up mode when does the image become clear again ? what adjustments are necessary to get a sharp image ? moving the camera further away ? change settings ? add more light ? does your camera have a setting called MACRO ? It seems your device has the capabilities to shoot clear video close up so let me know if anything I have suggested worked or was of no help .
How to put tv in video mode instead of mono
I am confused wit the question. Mono is an audio setting. And video setting are for just that. video.
2answers
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
4helpful
2answers
Hannspree HF 257 25'' monitor only stays on fo a few seconds and then gradually fades to black, another monitor works fine so the computer is not the problem. The computer was just moved to a new...
Is the power light staying on or does that go out as well?
If the power light stays on and if you darken the room, can you see a faint image still on the screen by shining a flashlight at it (close). If there is a faint image it is either the inverter or the backlight tube.
JC
2answers
When playing DVD, image sometimes dark incl. closed caption
1> sometimes supply of low voltage causes some disturbance in trasmitting video signals,it results in darker images while watching.
2> The DVD may have some scratchs or dust-spots or rough-coat on its recording surface ( reflecting LASER beam ) clean DVD and operate again.
3> your DVD player's SMPS (switched mode power supply ) circuitary fails to perform its function properly and giving irregular supply to video-audio card of the DVD player because of having some failure of electronics component housed on this circuitory.
4> switch the mode among 'PAL' , 'NTSC' , 'AUTO' and OTHER in playback mode options ,one by one taking  some minutes.
Now , your problem is solved , Enjoy,Bi.
3helpful
FinePix F470 Lines on images and faded colors on photo mode.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
Problm with viewsonic va712b
sounds like the operating mode is at a frequency or refresh rate that is outside the viewsonic operating specifications when in normal mode. possible solution: in safe mode access control panel, system, devices (hardware) and look for display. do a right click and uninstall. repeat right click and "scan for hardware changes". That might reset the monitor operating modes but it also gives you a chance to reinstall drivers. If this does not work, try other monitor crt/lcd to see what happens.
Any movement recorded in HD mode is not clear.
HD mode images may appear to move somewhat stiffly compared with SD mode or DV mode images. This is because they are shot at a rate of 30 frames per second compared with the 60 frames per second for the SD or DV mode images. The movie is shot at 24 frames per second, and looks good. So HD mode can have the same feel as a movie material. For smooth movement during video clips, we recommend you minimize rapid-panning or avoid shooting fast-moving subjects. Should you wish to record more natural motion in the picture, we recommend setting a slower shutter speed, or changing the recording mode to SD or DV.
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
