The subject of my video is a very slow moving tone arm on a record player
Blurry can be due to out of focus or camera shake are the most common if you are in video mode try turning off Auto focus and using manual or the other way around , next if the image is blurry while in close up mode when does the image become clear again ? what adjustments are necessary to get a sharp image ? moving the camera further away ? change settings ? add more light ? does your camera have a setting called MACRO ? It seems your device has the capabilities to shoot clear video close up so let me know if anything I have suggested worked or was of no help .
SOURCE: My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
SOURCE: My camera (a Canon PowerShot SX10IS, if it
I have the same problem with the same camera. I believe the problem can be solved by turning the knob to MOVIE mode, then push the menu button. When the menu screen pops up. Go to the "camera" tab. It should be the first tab to your far left.
Once you are at this tab, scroll to the very first option which should be the AF FRAME option (Auto Focus Frame). Select "CENTER" for the Auto Focus and do not select "face detect." I think when it is in face detect mode it is sometimes searching for the persons face. If you just leave it in CENTER mode, then it just fixes itself in the center. This is what I am going to try. I think it should work.
Hope that helps.
Peace
SOURCE: Nixon S8100 fairly new camera,
If everything in the picture is blurry, you are moving the camera when you press the shutter button. If only the subject is blurry and the background is clear the problem is too slow shutter speed. If this is cause by movement of the camera you must learn to SQUEESE the button while being sure you don't move the camera. It just takes a little practice. If this problem caused by a shutter speed that is too slow, it is remedied by increasing the ISO "film" speed. Even though you have no film, the camera has a "speed" setting that relates to that. The higher ISO value increases the camera's sensitivity to light and thus allows for faster shutter speed. Normally the ISO choices are 100, 200, 400, 800, 1600. Try using 400. The ISO setting is in one of your camera menus. 400 is fast enough to solve your problem in all but very fast movement of either the camera or subject. Using ISO above 400 will cause your pictures to look grainy and not as sharp. Use the highest speed only when absolutely necessary. Slower ISO numbers produce the finest grain and thus the sharpest pictures. It a trade off between ISO and shutter speed because the exposure is a combination of the ISO and shutter speed and lens opening. Each one effects the exposure by half or double.
