Jack Lalanne Power Juicer 250 Watts Logo
arcenia aciong Posted on Feb 27, 2012
I have a problem about my nikai juice maker,it was working at the beginning when i was trying to make a juice but unfortunately suddenly stoped and i want to know where i can find the shop or contact number of nikai co.here in riyadt to fix my juicer becoz it's just a new machine i bought..tnx
4 Related Answers
Anonymous
  • Posted on Apr 26, 2009
SOURCE: juicer with no "muscle".
I have a brand new one from Costco and it goes through carrots very quickly.
Anonymous
  • 356 Answers
  • Posted on Apr 04, 2010
SOURCE: motor stops, electric burning odor, starts after cooling period
1-973-287-5150. VERY SHORT WARRANTY. IF OUT
OF WARRANTY GO FOR SOMETHING BETTER.
GOOGLE FERNS NUTRITION, THEY SELL JUICERS
AND GIVE GOOD ADVICE. I HAVE AN ACME SINCE
1990 AND RUNS LIKE THE DAY I GOT IT. TAKE A
LOOK AT THE LEXEN GP62. THE HUROM SLOW
JUICER IS GREAT, BUT BIG BUCKS.
Anonymous
  • 356 Answers
SOURCE: Juicer is not economical in extracting juice; the pulp is juicy.
SHREDDER BLADE MAY BE DULL OR LOW RPM.
Anonymous
  • 356 Answers
SOURCE: Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
2answers
How do i get the screen filter out of juicer
I had the same problem with my Salton juicer, after making a delicious juice it was almost impossible to remove the auger like many of you, with patience and lots of elbow grease I manage to take apart. Here is my solution to this problem and it works very well for me, its simple, before juicing, disassemble your juicer and add a little oil with your finger on the silicon seal (inside and outside) see picture attached, assemble the juicer.
After juicing, remove the cover, don't try removing the auger, instead grab the basket and wobble it and it should get free, it works for me and it should work for you too. Happy juicing to all!
2answers
Santos juicer
Couple of things to look at
1 check the grating blade. Maybe clogged therefore need cleaning or need replacing due to bluntness
2 motor may be slipping true to overload. Place fruit in a little at a time
hope this helps
Apr 16, 2014 • Juicers
1helpful
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Where can i get an owner's manual for a Rival juice extractor model 965?
I tried to locate the manual with google, but unfortunately had no success. You could ask some specialized Rival manuals with the search engines, like here or manualsparadise.com. The services are not for free, but most times worthy - saved my live more than one time...
Jan 02, 2012 • Juicers
After juicing a few carrots[some of which were cut on a slant], or several spinach clusters, the machine seems to get off balance and begins shaking violently and making a racket at which point I have to...
There's nothing wrong. These juicers do not eject the pulp and go out of balance very
easily. If you continue to have problems you may have to go for a different type of juicer.
The Hurom or Omega VRT, expensive, look good if you're really into juicing.
Ican not remove the the basket for cleaning is to hard
You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Motor is humming not working .. stoped in between juicer
it is jammed, or it is too full....stop, take apart, scoop out pulp, put back together and restart. go slow when juicing...too fast will jam it!
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
9helpful
5answers
OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Top Jack Lalanne Juicers Experts
ADMIN Andrew
ADMIN Andrew
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
