20 Most Recent Acme 5001 Supreme Juicerator Juice Extractor Questions & Answers
disassemble clean and assemble paying attention to condition
noise from bearings going out/screeching ???
noise from unbalanced load/ lots of vibration??
noise from scraping/grinding/metal on plastic ??
noise from scraping/grinding/plastic on plastic ??
there any burning smell also ??
is any part getting warm ( turn upside down to check ) ( hold or place on thick layer of kitchen towels
be aware if it is old ~ 20 yrs give or take 20 yrs getting a new juicer will be less hassle than trying to repair
Acme 5001... | Answered on Apr 02, 2019
yes new rubber feet are available easy to install
same problem; looking for solution
Acme 5001... | Answered on Jun 03, 2013
REMOVE THE COVER BY ROTATING AND
THE CLUTCH NUT HOLDING DOWN THE
CUTTING BLADE. EVERYTHING LIFTS OFF.
CLEAN ALL DISCOLORED PARTS BY FIRST
BOILING IN A SOLUTION OF OXI CLEAN AND
WATER, THEN SCRUB WITH A SAFE
ABRASIVE SPONGE. SHE WILL SHINE UP
NICE.
Acme 5001... | Answered on May 08, 2013
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
Acme 5001... | Answered on Jan 06, 2013
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Acme 5001... | Answered on Jul 24, 2012
the rubber banding on the bottom of the shredder disk gets worn over time and you might need to buy a new shredder disk. I was experiencing the same problem (the juicer was vibrating at an odd speed,shaking and the sound of the motor was distressed, when the plunger was inserted to push down the veggies it was banging and making an awful noise) replacing the disk solved the problem - good as new.
Acme 5001... | Answered on Apr 25, 2012
WARING HANDLES THEM AT 800 492 7464.
HOW OLD IS IT? BEARINGS COULD BE GONE.
THEY ARE REPLACEABLE.
Acme 5001... | Answered on Feb 16, 2012
Tip
How to keep your juicer from jumping all over the place.
I have found celery is the big problem, instead of putting in the whole stalk cut
it into small 2 inch pieces, when I do this I have no problem, otherwise my
juicer is jumping all over the counter. I believe it is the long strings in the
celery that somehow gets caught around the parts. At least it has made
juicing a pleasure for me. Hope it works for you.
If this has helped you please let me know, [email protected]
on Jan 26, 2012 | Acme 5001 Supreme Juicerator Juice...
I found that one here.
I searched this for you, please leave a good rating!
Acme 5001... | Answered on Dec 28, 2011
Try the reset button on the bottom of the juicer.
Acme 5001... | Answered on Apr 26, 2011
Juice bowl goes on first, then basket, blade, clutch nut followed by cover which
rotates shut, and of course the food plunger.
The white impeller that you attached the basket and blade to is
keyed to the motor shaft. There is a small shallow nut that you
can remove with a needle nose pliers and pull the impeller off
the shaft to see if it's seated properly or damaged. If damaged
talk Waring into selling you another at 1 800 492 7464.
You may have tripped the reset button on the bottom of the juicer, just push
it back in. They really don't have to warm up, just give it a few seconds to reach
speed.
Not really designed for juicing oranges. There is a citrus attachment but it costs too much,
better off buying a $20 citrus juicer.
Acme 5001... | Answered on Apr 20, 2011
Acme 5001 Supreme Juicerator Juice Extractor Logo
89 questions posted
Popular Products
Top Acme Juicers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Acme Juicer Expert? Answer questions, earn points and help others
View Most Popular
Acme Juicers
  • Acme Juicers
Most Popular Question
acme juicerator
  • Juicers
