Computers & Internet Logo
Asihiquzzaman Posted on Jan 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't open a cdr file from Illustrator CS3-5 any body do help me?
Alexey Krenvalk
Level 2:
Sergeant:
Champion:
  • Expert 419 Answers
  • Posted on Jun 21, 2012
Alexey Krenvalk
Expert
Level 2:
Sergeant:
Champion:
Answers
419
Questions
0
Helped
309182
Points
517
Unable opening .ai files must be file corruption
In such case I would suggest you next utility http://www.illustrator.repairtoolbox.com
5 Related Answers
EL FADIL MOHAMMED
  • 423 Answers
  • Posted on May 29, 2009
SOURCE: I reinstalled the CS3 version but only Illustrator does not open
1 download tune up utilities 2008
2 uninstal the software
3 scan registry errors
4 if this is not works contact me at [email protected]
i can give you a direct link to download a full version of cs3
hope it will help you
chamboard
B.Th. Pluijm
  • 558 Answers
  • Posted on Oct 17, 2009
SOURCE: I want illustrator cs3 crack.. plz
try serials.ws
Anonymous
  • Posted on Oct 30, 2009
SOURCE: What are the colour settings in Illustrator CS3 to
sigmatel fxd s 400 softwere
mo. 9737470042 send answere
Anonymous
  • 1752 Answers
  • Posted on Nov 14, 2009
SOURCE: please help me! :( ı can use
Sorry, giving away activation codes is illegal on this site.
Anonymous
  • Posted on Feb 07, 2010
SOURCE: hey experts need ur advice plz ??
The best way to do this is to create a mask. That way when exporting the image, you only show the portion of the image you want to.
To create the mask, first create all the artwork you want. then in a top layer, create a no fill, no line shape (whether that be a box or a circle or a shape of any kind– for simplicity sake let's keep it a rectangle for now making sure you have the rectangle sut off some of your image to see the effect later.) Make sure you have all your layers unlocked and then select all. This will not only select all of your artwork, but will also select the no fill, no line shape you created in the top layer. Then right click and select create mask. The effect will then appear right before your eyes!
And what is so great about this is that if any changed need to be made later on, you can go back and change the mask layer later to include or exclude any of your original artwork!
Enjoy!
CDL
Error opening file in Adobe Illustrator
Create New Illustrator File:
    -Double-click the Adobe Illustrator icon on your desktop to open the program. Click the File drop-down and select the "New" option.
    -Choose the size and color mode for the file and then click the "OK" button.
    -Click the File drop-down and then select the "Place" option. Choose the "All Formats" from the Files of Type menu when the Place dialog box appears.
    -Select the damaged Illustrator file and then click "Place." Enter a new name for the file and then click "Save." This will create a new Illustrator file with information from the damaged file. or you can try to use illustrator recovery , this is nice PAID service . i wish you good luck
How to recover corrupted ai file of Adobe Illustrator
1helpful
Adobe Illustrator file format is having difficulties
There may be a TMP file in the same folder, you can try renaming it to AI and see if this opens. Helped me on a couple of occasions but also has not worked in the past.If it useless, there is a good program: Illustrator Fix Toolbox https://www.fixtoolbox.com/illustratorfix.html
1helpful
2answers
How to fix adobe illustrator?
Maybe try repairing permissions, restart, and try to open the files. This might work.
Also u can repair illustrator file owing Illustrator Repair Toolbox I found it here
1helpful
2answers
How to repair illustrator file?
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
http://www.illustrator.repairtoolbox.com/
1helpful
2answers
Adobe illustrator file corruption. What to do?
First check your illustrator. Could it open other files or not? Try to create new file and save it, then open again.
Try to open your corrupted file on another PC. Then if it doesn't work, it means that your file is corrupted. So you should try to restore it by Recovery Toolbox for Illustrator . You can download it here http://www.illustrator.recoverytoolbox.com/
Also you can read here about corrupted file recovery: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/513-adobe-illustrator-file-corruption
1helpful
Saved illustrator 10 file gets corrupted
Check for a damaged pattern, gradient, or custom color
To determine if the problem is caused by a damaged pattern, gradient, or custom color:
1. Choose Edit > Select All and change the fill and stroke to process black.
2. Perform task 4 again to determine whether the problem occurs in a new file that does not contain the patterns, gradients, or spot colors. If the problem does not recur, re-create the pattern, gradient, or spot color in the original file.
Otherwise:
First option: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/383-%E2%80%8Bcorrupted-fonts-in-illustrator-file-urgent-help-need
Second: shareware tool Illustrator Repair Kit
See more about:- http://www.illustrator.repair/
2answers
I cant open a new file, template or old file. My Illustrator CS just crashes. Please help
Double click on My Computer on your desktop and open C:>Documents and Settings > User >Application Data > Adobe > Adobe Illustrator CS2 Settings. (Your version of Illustrator will be in the foldr name.) Inside this folder is a file called AIPrefs. Drag this file to the trash, and restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
You can also reset Illustrator's preferences by holding down Shift + Control + Alt while launching the program. If you get a dialog asking if you want to delete the Adobe Illustrator settings folder, click yes to proceed. Restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
1helpful
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Grand Canyon Tech
Grand Canyon Tech
