The computer starts up, goes to the Dell logo screen with f2 for setup and f12 for boot options but then when it gets to the starting windows screen, it automatically freezes, and the only thing I can do is turn it off. Before that it allows me to choose "launch startup repair" or "start normally", but the launch startup doesn't help. What can I do to stop this problem?
SOURCE: my Dell xps 600 won't startup
have you check the hardware of your computer? try to change the memory of your computer. and check the cables of your keyboard and mouse.. if there is any problem again try to contact me. thanks!
SOURCE: after i enter into dell bios by entering F2 the
try to check on the keyboard, no the buttons of the keyboard, one might be stark from inside and so try to pull it out .
SOURCE: i have a dell 3100 when I turn it on all it says
your windows is corrupted.
please install your windows again.
an if you don't want to loose your personal data,then only format the "c" drive of your computer.
remember only local drive 'c'.
THANK YOU
SOURCE: Boot fails at Dell Inspiron logo at half way mark
you need to reset the processor and test your ram, one last thing make sure your dvd rom is working check cable make sure its connected
Testimonial: "Resetting the processor is something that would not come to my mind as a resolution. However, I did along with most others. It worked. Thanks!"
SOURCE: I am trying to reinstall
Check the Date and Time setting, if these are wrong you will get the Strike F1 and F2 message.
OR
The BIOS battery is flat and it won't save the BIOS settings. In this case, replace the BIOS battery and configure the BIOS again.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then shut down your computer and try again.
I hope this answers your question!
