Need to know how to change the stitch size. Work mainly with leather
SOURCE: How do I change the stitch length in my Juki LU
hi there
the graduation of the stitch length is marked on the feed graduation plate attached t the main shaft,to adjust the stitch length rotate the hand wheel slowly as you keep pressing the push - button stop the bed until the tip of the push- button enter groove of the accentric mechanism, when it is entered rotate the hand wheel eigher towards you or away from you as you keep pressing the push - button until the desired stitch length indicating mark on the graduation plate appears on the hole of arm. when appear release the push - button and check stitch length.
BEST REGARDS
AHRAF ABOZID
CAIRO - EGYPT
SOURCE: I need a manual for a JUKI LU 563
JUST check at google ,com manuals
and then write you model# or you can go directly to your manufactury on line or if you heve costumer service # call them
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
hi there,
if you don't mind, i have old instruction manual ( PDF copy ) i can send to you. please send to me email to [email protected]
best regards
ashraf abozid
CAIRO - EGYPT
