20 Most Recent Yamata FY700 Mechanical Sewing Machine Questions & Answers
Primera aprenda english..es el lenguaglobal. Compra un clymer manual for repair
Yamata FY700... • Answered on Jan 31, 2019
If it is a mechanical machine, a thorough clean and oil may be very helpful. (You are wise to avoid using the machine until the problem is addressed as the motor could be damaged.) Wheel on right side that controls the needle up and down is very tight...
Yamata FY700... • Answered on Nov 29, 2017
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Yamata FY700... • Answered on Sep 25, 2017
Is this a machine where you have to tightnen the clutch in the middle of the handwheel? Or is this one where the clutch disengages when you switch the bobbin winder on? If it's of the second type, try turning the bobbin winder on again, and then off, crisply. Otherwise my best guess, barring other information, is that the lubricants have gone gummy or evaporated. Do you hear a motor hum?
Yamata FY700... • Answered on May 25, 2014
In the lower right hand corner of the bobbin case area, there is a small finger-like spring structure. Gently lift it and push it to the right. Take the bobbin case in hand and inspect it. It is a round piece of metal with a groove running down the edge of it. Now look at the hook, or the round piece of metal that is in the bobbin case area. It has a slight shelf-like structure. Place the bobbin case groove into the shelf-like structure in the hook so as to make it sit flush. With your finger, take the front of the bobbin case and push it to its left so that it is as far counterclockwise as possible and replace the spring.
Hope this helps.
Yamata FY700... • Answered on Sep 04, 2013
It doesn't look like your machine has the ability to increase the pressure on the presser foot.
Yamata FY700... • Answered on Dec 04, 2012
It would be called a Needle plate or Throat plate. Good luck finding them, I've never seen anything in the domestic machines... and industrial machines are just as difficult to find. Check with whomever you purchased it from. Perhaps they can direct you to a parts place.
Yamata FY700... • Answered on Nov 30, 2012
you can go to the store of juki sewing machine,
Yamata FY700... • Answered on Oct 24, 2011
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 9410 ) & click search
They have a free download,,the second one is free
Yamata FY700... • Answered on Sep 05, 2011
Yamata FY700 Mechanical Sewing Machine Logo
50 questions posted
Top Yamata Sewing Machines Experts
Michael Thomas
Michael Thomas
ADMIN Canada
ADMIN Canada
Ruth summersides
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Yamata Sewing Machines
Most Popular Question
broken feeder plate
  • Sewing Machines
