My lamp ballast is bad and i have this one out of other tv
SOURCE: Resetting lamp hours
You will need to enter the service menu to do this. However if you were to push the wrong button on the remote you could really mess up the tv. So I suggest you call Sony and see if you can get an ASC to do it for you for a minor charge. There are literally hundreds of electrical adjustments in this service menu. I would adcise an asc do this for you.
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
SOURCE: I TOOK IN MY KDS-R60XBR2 TELEVISION. I WAS GETTING
Hi my name is Roety,
I can help you with your issue ,
There are 3 fans, but the main one is the one that usually goes bad location 103 here , The fans only cost about $20 each and are easy to change.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: RESET LAMP HOURS ON SONY KDS-R50XBR1 sxrd tv
Click here to download the user'e guide and go to page #113 to reset the TV to factory settings.
