SOURCE: Navigation fatal error Error 1706
yes..I saw that..need teh model number of the actual gps you are using, please..
SOURCE: nvx430bt jensen gps initialization error no language files
Hi.
This happens when the language files stored in your Jensen's memory get damaged. The Sat Nav system will look for new language files on your USB memory, and return the error.
Often the problem happens because you formatted the disk.
I suggest to start trying to set language to English.
In theory you are supposed to restore the flash image from original CD or computer backup.
A first attempt to fix the problem can be done resetting the Sat Nav. Just take out the battery for ten seconds.
If you have the original CD, files to be restored are in the IGO folder, and must be copied into the flash disk.
Files to be copied are
If that does not work, contact Jensen/Audiovox clicking here, they will enable a download of the language files to replace the damaged ones.
SOURCE: mi mp3 nextar solo dice file system error y se apaga no se escuch
cuando le cambie las batterias solo dice file system errror
