20 Most Recent Nextar MA7151B MP3 Player Questions & Answers
Perhaps your audio book was from audible.com. They use their own audible format ( .aa instead of .mp3) and only certain mp3 players can play .aa files. If the book is in .aa format, go to www.audible.com and check to see whether or not your player is compatible with .aa files. If not, you're outta luck. durok
Nextar MA7151B... • Answered on Nov 26, 2020
Best first bet is dead battery. If it is a special battery then do the costings for the repair as it may be cheaper to replace the player.
Nextar MA7151B... • Answered on Jun 13, 2017
I PLUGGED IN MY MP3 PLAYER TO THE COMPUTER AND THE SCREEN ON MY MP3 PLAYER LIGHTS UP BUT the normal screen image for when you normally plug it into the computer ISN'T THERE AND I CAN'T ADD MUSIC ON MY MP3 PLAYER.
Nextar MA7151B... • Answered on Dec 29, 2016
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. OR Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
Nextar MA7151B... • Answered on Dec 13, 2012
Hello.
You can use a USB cord.
Connect your unit to a PC.
And it will be charge via USB.
Nextar MA7151B... • Answered on Aug 29, 2010
hi sir
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nextar MA7151B... • Answered on Aug 28, 2010
Here's a few ideas (with so little info on your problem):
1-scroll up and down the menu with the left/right arrows, hit the M button to play whatever selection (music, video, ebook...) is showing.
2-REGULAR MAINTENANCE: when your Nextar is connected to the computer via USB, open My Computer, right click "Nextar", select 'properties'. Under 'tools', check for disk errors and defrag the Nextar - and Backup if you want.
THIS should help!
Nextar MA7151B... • Answered on Aug 22, 2010
Not really enough info but to turn it on, hold down the pause/play button until you see a screen coming on. After the main screen loads, whatever is selected from the menu (music, video, ebook...) will play when you hit the M button.
To scroll up and down the main menu, use the right and left arrow buttons.
I have a 797 model. By plugging into the computer thru the USB that charges it, I go under My Computer, select Nextar.
When it opens, I drag and drop from files or iTunes.
But you have to make sure you are choosing mp3 versions, won't play just anything like and iPod.
But iTunes converts to mp3. Think it is under tools. Select an audio, under tools?, select convert and you can go from there.
Not sure if either of these helps, but hope so:
1-After you boot up/turn on, is the word "Music" showing in the window? If not, use the right arrow button to move the menu to Music, then hit the M button and it will start playing.
2-Mine (797) has a bad headset hole so only plays one ear unless I push up in the plug wire. I just put a rubberband tightly around the plug and pull the band up over the top to pull it into a position where I can hear both earsets.
it does this get used to it.
The MP3 player is charged by connecting the USB cable from the player to the USB port on the computer or on a USB power supply adapter. Don't forget to turn on the MP3 player.
Nextar MA7151B... • Answered on Apr 04, 2010
hmm.. i have been having the same issue. my Ipod touch is full and i cannot delete any songs without syncing the whole iPod, which I do not want to do as there are a couple of songs i don't want to lose! help..
Nextar MA7151B... • Answered on Apr 01, 2010
Nextar MA7151B MP3 Player Logo
84 questions posted
Top Nextar Audio Players & Recorders Experts
Tom Chichester
fretlessbass
fretlessbass
Level 1 Expert
Mr.Mike
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Nextar Audio Players & Recorders
Most Popular Question
get songs player
  • Audio Players & Recorders
