Is the coolant clean that leaks out? Have you put a newspaper under the car to try and isolate the leaks location by the drip stains? Likely spots are the engine water pump and hose connection points at have worked loose. If the leak seems to come from the rear of the engine it may be a leaking heater core, in that case you should have a kind of sweet smell (the smell of vaporized coolant) in the cabin when the heater is on.
Get the
coolant pressure tested, its definitely leaking coolant. You will need to get
the coolant running line.
Pressure
test will help you to know from where exactly coolant/refrigerant is getting
leaked.
For complete
step by step troubleshooting i suggest you to go through the help link mentioned below :----
Click
the link below: -----
COOLANT
LEAK ISSUES, COOLANT LEAK PROBLEMS, COOLANT SENSOR, LOW COOLANT,
http://alltypesofpartsreplacing.blogspot.com/2012/12/coolant-leak-issues-coolant-leak.html
These will help.
Thanks.
