SOURCE: change date/time on ecg
Need to know which machine it is first. If you have changed the date and time and it wont stay, it could be that you need a new internal battery. If you just can get it to change, let me know what model. [email protected] or 800 989 4909
SOURCE: I wish to down load Operations and Service Manual
I have it, let me know if you still need it. [email protected]. www.overstockme.com. Jeff Watson
SOURCE: loading paper into the MAC 1200 ecg machine
1. Switch on the recorder
2. Pull up the handle of the paper door and fold it out
3. Remove the cardboard from the top of the new pad and place the pad, including the cardboard backing at the bottom and with the arrow pointing towards the unit, into the paper compartment
4. Pull the top sheet out of the compartment and guide it around the guide roller
5. Holding the leading edge of the paper in place between the two markers on the recorder, close the paper door. Ensure that it locks into place on both sides.
- When inserting an already started Z-fold pad, the grid side must face up and the first fold must point the compartment.
(You can find more information at MAC 1200 Operator's Manual, there page 59.)
SOURCE: how do i change the TIME on my Marquette ECG
setup, time date then type in the correct info. Make sure you use the correct "separator" for the time and date. You need to put in the ":" for time and the "\" for date or whatever your system calls for. If it keeps on loosing time and date settings you will need to replace the quarter sized lithium ion battery that holds this info.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com
