The error indicates that there's a hard drive issue. If it just happened after the hard disk is reinstalled, remove it and reinstall it. It could be a problem caused by loose connection or improper connections. If the same problem repeats, install the hard drive on another system (to verify whether it works on another machine or not and to confirm it still works). If it doesn't work on another computer/system then your only option to run the system is replacing the hard disk. If it works on another computer or if it's detected on another system, then there could be problem with the hard disk, eg. Corrupt Partition, Windows Corrupt etc....
First of all, try booting into Safe Mode. You have to press F8 during the startup to go into Advanced Boot Options. Once you are in the Windows Advanced Boot Options, select Safe Mode using the up and down arrow keys on your keyboard. If it still doesn't work, it's the hard disk issue. Try with another Hard Disk.
But if in case you can boot into safe mode, check the Hard Disk for errors. In other words, run Windows Checkdisk utility. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
For more details from Dell, please try this link;
http://support.dell.com/support/topics/g...
What is the Service Tag of this machine?
Why do you need to know the service tag?
To verify the age of the components of the machine along with the specific type of hard drive installed in your computer.
