Janome Memory Craft 9000 Computerized Sewing Machine Logo
Posted on Aug 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The hand wheel on my Janome 9000 has become very tight and hard to turn. I am still able to sew but something isn't right.
Anonymous
Level 2:
  • Expert 208 Answers
  • Posted on Aug 22, 2011
Anonymous
Expert
Level 2:
Answers
208
Questions
0
Helped
112061
Points
701
It is very likely that the main shaft bushing on the handwheel side has failed. It is very easy to diagnose. With the top cover removed, one can inspect the bushing for any discoloration seeping from the bushing. If that is the case, the main shaft and the bushing will need to be replaced. Not a big deal, I've done lots of them, but definitely a job for an experienced technician. [email protected]
Model mc9000. Needle moves manually. Why not automatically when machine started?
Do you mean that the needle goes up and down when you turn the hand wheel but not when you step on the pedal? In that case, your machine needs a new motor belt. I've seen some of these listed at E-bay. The service manual is available from ManualsLib, https://www.manualslib.com/manual/1075981/Janome-Memory-Craft-9000.html#manual . To remove the belt unit cover, see https://www.manualslib.com/manual/1075981/Janome-Memory-Craft-9000.html?page=4 . The belt is shown here: https://www.manualslib.com/manual/1075981/Janome-Memory-Craft-9000.html?page=18#manual .
Warning: since this is a computerized sewing machine, you should have the service done by a sewing machine repair person. There are parts of the machine that may still be energized and touching the wrong spot could damage the machine. If you are skilled with this type of work, you can ignore the warning.
I hope this helps.
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Janome 9000 growls---safety message comes up---handwheel hard to turn
You've got something wrong. Call the Janome help line.
Blowing fuses. Get a vibration first
If you've checked all of the 'usual' things (cleaned, lubed the machine according to mfg. directions, new needle, etc.), take all of the thread off and try sewing for a bit without it. Same symptom? Take it for service!! Could be faulty wiring. If not, your tension may be *way* too tight. Try loosening it up a bit, first the upper tension then the bobbin, but adjust slowly - it's really easy to miss the 'sweet spot' for tension.
Hope this helps.
1helpful
2answers
My 9000, on regular sewing, is My 9000, on regular sewing, is "jumping" ahead as I sew....kinda like the foot pedal is stuck. Anyone every have this and if so, is it something I can fix or do I need t
it's definitely not suppose to be jumping ahead.
have you checked the foot your using on the machine to make sure it's on correctly?
you might also check the feed dogs to see if there in the up position, in the needle plate.
if nothing I suggests works then I agree to take it to a janome dealer & let them sew on it & see what it does with them
1helpful
My Janome 9000 also quit a few months ago, took it to repair shop and they replaced a fuse. Have only used it about 2hrs since and it did the same thing again. So we decided to replace fuse...
Your fuse is blowing because there is a bind in the machine. Did they service the machine when they replaced the fuse? If yes, it should be under warranty. Best guess is that it is tight from lack of lubrication, usually at the bushing nearest the hand wheel.
sewman7
2helpful
The 9000 janome sewing machine works fine but when i turned it on the lighted computer screen is so light i can hardly see the images. i need to darken it so i can tell what stitches i want to use.
hi just above the screen if you look in side the machine where your cotton fits their is a little wheel you can spin to adjust your screen hope this helps
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
