1. Launch your web browser.
2. In the
Address: or
Go to: field, type the IP address assigned to the
printer (for example: http://192.168.1.1) or the host name (for example:
http://myprinter).
If you do not know the IP address for the printer, it is listed on the
printer configuration page under Protocol Information in the TCP/IP
section.
To print a configuration page:
a. On the printer control panel, press
Menu until INFORMATION
MENU displays.
b. Press
Item until PRINT CONFIGURATION displays.
c. Press
Select to print the configuration page. After the process is
completed, the printer will return to the READY state.
From there, you can configure the printer using the web GUI. Consult the manual if you need at:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl10150/bpl10150.pdf
Hope this helps, and have a good weeked.
