Acer-Veriton-M410-US3800P AMD Desktop PC - AMD Sempron 2.2GHz, 1GB DDR2, 160GB SATAII, DVDRW, Gigabi Logo
Posted on May 22, 2017
I have a Acer Veriton M410 and if I try and add additional memory the PC will not boot, just beeps. I tried every combination of ram with the same negative results. The system came with two sticks of 512 meg ram. The dealer swears I have the right ram. I took out my original ram and tried two 1gig sticks in four different slots. I put my original sticks back in and it works fine. Can it be a bios issue? I have swapped out ram for many a year and never had this problem. Need help with this one. Thanks.
Larry Welch
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on May 22, 2017
Larry Welch
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
10
Questions
0
Helped
4056
Points
24
That motherboard will use any of these 3 memory sticks.IN PAIRS.if you just put in 2 make sure the go in the same colored slots.
DDR2 PC2-4200
DDR2 PC2-5300
DDR2 PC2-6400
Each slot will take upto a 2gig memory stick.For a max of 8gig.
Use matching pairs.
5 Related Answers
Eddie Guarraro
  • 38 Answers
  • Posted on Feb 05, 2009
SOURCE: Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Anonymous
  • Posted on Nov 24, 2007
SOURCE: Increase Memory.
Good luck. Window will only recognize 3.2 gigs if yours is a 32 bit system. Acer tech is not existent as far as I can tell.
nkprl
nik parelos
  • 54 Answers
SOURCE: acer t180 ud360a memory
to access bios press on boot F2 or DEL or F10
it seems that you have to flash your bios
check acer site for new bios http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=3889&formid=3394&website=AcerPanAm.com/us&siteid=7293&words=all&keywords=&areaid=7
Anonymous
  • Posted on Nov 30, 2007
SOURCE: Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Anonymous
  • 15 Answers
  • Posted on May 23, 2009
SOURCE: Incorrect RAM reported on BIOS
4GB RAM requires a 64 bit compatible processor AND Operating System to be able to access
addresses in memory that exceed the 32 bit assress space.
I'm not familiar with the motherboard that you are using but simply expanding RAM isn't enough if your
system isn't 64 bit compliant. Assuming it is, then ensure that you are using a 64 bit version of Windows 7 opposed to a 32 bit release candidate.
Comp.turns on. fan runs.. but no boot up. nothing on monitor.
first of all did you try new lead to your monitor check you have power to your monitor
2answers
Acer Veriton 3900 Pro - I have a green light on the front but the computer will not power up
If your computer no beep when starting just check the videocard and RAM or memory inside and remove it then clean with the pencil eraser or rubber in the pin and insert back again then try to power on your computer. If did not solve the problem just check your monitor if did not have a problem. But if your computer have a one beep when starting it means no problem on your computer. The problem is in your monitor it could be have a damage.
Describe your acer veriton m410 problem Problem: Power supply works but no video or keyboard or mouse. USB mouse was acting strangely before the end
Mobo may be fried. Best suggestion, take it to your local computer repair shop and have the CPU, NPU, Memory, etc. tested.
8helpful
4answers
Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
How do I fix a boot loop on my acer veriton m410
Try loading to Safe Mode (probably F8 or Delete key upon bootup). If unsuccessful, you probably will need to reinstall the operating system.
Computer keeps restarting itself after about 10 - 15 mins.
Start the PC, Click Start > Right Click on My Computer > select Properties > Advanced tab > Settings (in the Start up and recovery section) > Unckeck the box next to "Automatically restart" under "System failure". > click "OK" > click "OK" again. Restart your PC and give it a go.
Keeps rebooting at logon screen
Possible faulty ram, did you update any software recently (prior to the endless boot cycle)?
2helpful
2answers
Acer Veriton 6800 PC Desktop will only beep will not boot.
Hi Just checking first of all you have tried another memory module. This sounds like a faulty RAM. Please try and get back to me if that doesn't fix it. Thanks, Lolita
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
