2006 Saturn ION Logo
Anonymous Posted on Aug 08, 2011
My ac in my 2006 saturn ion blows cold air when its under 80 degrees outside but when its over 80 degrees it will blow warm air sometimes and cold sometimes what could be wrong with it
  • Anonymous Aug 08, 2011
    the freon was checked and its ok what else could it be
240cpa
Level 3:
  • Master 548 Answers
  • Posted on Aug 08, 2011
240cpa
Master
Level 3:
Answers
548
Questions
8
Helped
213733
Points
1639
You likely need to charge the AC with freon. If it has been a year or three since you've had it checked, it is probably low on freon and needing to have some added.
  • 240cpa Aug 09, 2011
    http://www.aa1car.com/library/ac98.htm
    Since there are multiple potentials for the cause, please check the link above to see which ones you can eliminate. I didn't mean to leave you hanging but this is an issue that is not easily diagnosed.
I have a 2007 Saturn, Aura. Heater does not blow hot, slow coolant leak, & it also over heats. Please help! I'm freezing when I'm in my car!!!
You need to fix the coolant leak, then refill and bleed cooling system, then you will get heat and cure overheating problem too
Saturn vue ac
How do you check an orifice? Oh the high pressure side it will be warm to hot to the touch. The cold low pressure side will be much colder 45-50 degrees. if there is little difference and the charge is good the orifice could be plugged.
200R SATURN ION 3 AC BLOWING COLD AIR. HAD TECH PLACE FREON BECAUSE IT WAS LOW. NOW BARELY BLOWING COLD AIR WHEN IN PARK.
Some times we overfill the system when charging it up if this is not the case then go back to the tech...oh and check your relays, they are under the hood in a fuse box and marked you will need a precision screw driver set to do this as you will need to carefully uncover the relays if you are not sure that they are making a clicking sound which indicates that they are still good. there are high and low speed relays or it could be your check valve acting up. In any event go back to the tech if not sure what to do.
Dual-Zone AC Problem
My guess is that one of the hose's has a leak and needs to be replaced. A mechanic can run some tests to check if that's the case. Best of luck.
2000 saturn,is blowing hot air even after I charged it and the ac coompres
I would make sure the shut off valve between the cold air and warm air is engaging. this is controlled by a vacume
Volvo 960 AC problem
TX valve freezing?
1helpful
Air conditioner blowing warm air in saturn ion
if the AC is blowing worm air you need to get your AC recharged if you have alredy done that you should get the compressor checked (it sometimes seazes up or the cluch on it will seaze and you will need to replace it
i hope this helps
1helpful
1helpful
A/C is not blowing cold air and clutch on the compressor will not engage.
Most likley needs to be recharged. Shouldnt be low, but if it has ever been in an accident it may have a leak or your mechanic stole the refridgerant when it was cold outside and you didnt notice untill you turned the ac on.
2001 bmw 325i AC blows warm
PROB NEEDS 2 JUST BE RECHARGED. BUT STAY AWAY FROM THE DEALER. IT IS ALWAYS 3 TIMES MORE THAN A PRIVATE SHOP
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
