1)disconnect the battery for 5-10 min. 2)then insert it properly.3)then try. Alternate- flash your phone with JAF/PHOENIX software from rapidshare,4share website.
Hi. I had the same problem and fixed it by clearing all the phrases. An explanation of how to do this is below (written by someone else, not me) But, expect your guide beat to now sound like a fuzz instead of a drum. This really sucks and there is apparantly no fix for the guide sound except to send it back to Boss. Good luck.
1. Start by selecting Phrase 1.
(if the 'REVERSE' or 'AUTO START' are lit press them off.)
2. Select 'INST & MIC' by pressing 'MODE'
3. Hold down 'EXIT' and 'AUTO START' together - at the same time, this should light up the green LED for 'LOOP PHASE'
4. Hold down 'WRITE' and 'EXIT' together then hold 'WRITE' on its own then 'WRITE' and 'EXIT' together again...as if you were clearing a phrase.
they should light up in red and flash, if not try a combo of section 4.
you can store phrases by -
1 - turn on the AUTO RETURN button above the keyboard
2 - hold down the button on either side of the spacebar, type a titile (any character from a - z)(SPECIAL ENTRY light will turn on)
3 - hit the +/= key (if you hear a beep, it means this title is already used. Press STOP and start over with another title.)
4 - type the phrase
5 - hold down the special key on either side of the spacebar and hit any key (a - z) to store the phrase (SPECIAL ENTRY light will turn off.
to re-call a phrase
1 - hold down the key by the s/b and type the title (SPECIAL ENTRY light turns on)
2 - press the SPACEBAR one time
change the rom or hard reset,to do hard reset first press the big blue button and hold it press and then press the power swich,the message master reset will apear and choose yes.By doing this you will loose everything on your phone
