Ovens Logo
Posted on Aug 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire oven, set over to Clean and during the clean process had a power failure. LED has "LOC", cannot open oven. I have powered oven off and back on to no avail.
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Aug 06, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636860
Points
7414
One thing you could try is to set the oven to clean and see if the clean cycle will turn on then push cancel/off and see if the door opens. IF that doesnt work the door latch failed and must be replaced. to open the door ya have to pry open the latch by usinga wire hanger and try to slip it between oven door and top and pull to the left side to open latch
Good luck,
Gene
I misplaced my manual and need to have instructions to use the self-cleaning feature.
First take out the broiler pan, insert and any aluminum foil. Remove any other tools or pans from the oven. Next clean any large deposits in the oven cavity with hot, soapy water and a cloth. Clean the oven frame, the area outside of the door gasket and the very front center of the oven bottom with soap and water. Once you are ready to start the Self-Clean cycle, press the Self-Clean touch pad. To change the length of the Self-Clean cycle, press the pad again, as needed. Press Start. If you want to have the Self-Clean delayed, press the Delay Start touch pad after the Door Loc message appears. Type in the start time with the keypad.
To stop this cycle, press Cancel. If the oven is hot, the door will remain locked.
Frigidaire has most of their manuals available on their support site: http://b2b.frigidaire.com/support/manuals.asp . The current link to the English version of the Owner's manual is http://manuals.frigidaire.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Lassomption&PDFtype=Owner&PDFfile=318205312en.pdf&model=FGEW3045KFB . See pages 24-25 for this information.
I hope this helps.
How do I clean my Frigidaire electric oven, Model FEF352AWF?
See page 13 for specific instructions.
ShopYourWay FRIGIDAIRE Free Standing Electric ShopYourWay
As tedious as it may seem I suggest that cleaning the unit by hand is the preferred process. Most failures that I have experienced have occurred just after the clean cycle is completed. There is a lot of stress during self clean and critical components are stressed and are more likely to fail. On two occasions I have had a failure days before family dinners. Usually in preparation for family we had been cleaning the oven. Both the temperature sensor and heating element have failed.
With a free standing oven repairs are a lot easier than with a built in wall oven requiring saw horses to remove and set. In any case plan to clean long before company in the event a repair results.
Why You Should Almost Never Use Your Oven Self Cleaning Function
1helpful
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
MY OVEN WON'T HEAT
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
Power failure control panel beeps no lights on panel and oven wont turn on. have lights on inside of oven. do i need a code, never have before. always showed PF for power failure.
Was the oven doing a self clean when the PF occurred? If so the cavity limit probably tripped.
Sometimes the owner wants to shut down the process of self clean for whatever reason that also trips the cavity limit. If the oven circuit breaker is weak then their could be a power failure during which the oven was on and that could cause the cavity limit to trip. No lights on panel means the temp inside the oven control panel exceeded normal operating temp and the small inline fuse going into the control panel has melted:
This is what that small fuse looks like. To get to the insides
you usually drop the side trim exposing the screws then the controls fold outward.
Service manual for American stoves and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Code "door" when setting CLEAN cycle.
if it is OPEN IT IS RIGHT IF IT IS CLOSE IT IS WRONG
1helpful
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
1helpful
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
I started to clean the oven and just befor the lock locked, I checked inside. The oven door now is stuck and the lock engaged. What can I do?
Hi
Try switching the power off at the wall switch and then back on again. It may be that you also have to wait for the oven to go through the clean cycle as it is safety locked during auto clean.
2helpful
2answers
I accidently pressed self clean instead of boil on my oven
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
