20 Most Recent
Craftsman 16" High Garden Tractor Snow and Dozer Blade Questions & Answers
Sno trac snow blower parts manual
For anyone still hunting for Sno-Trac parts, these snow throwers were made by MTD and they can find parts diagrams for these units but you'll need to call their parts support 1-800 number for support. They helped me with my 318 586 502 1988 8/26 Sno-Trac. Canada:1-800-668-1238mtdparts.caUSA: 1-800 269-6215mtdparts.comAnyone looking for parts for this particular unit can look at that attached images
I bought this dozer blade uses and cant figure out
You can go to sears.com and lookup the tractor part number and snow blade part number and they will show you all the brackets and attachments needed. Also the site will show all tractors that the snowblade will fit. Hope This Helps Don
Manual needed
Go to www,managemylife.com and download your free manual
Roper snowblower drive chain keeps coming off
sounds like you have either stretched chains or worn sprockets. Also check the outer bearing that the shafts fit into for wear. If they wear then the chain can't retain it's tension properly, get sloppy and then derail itself. Most likely your bearings is the problem.
5hp briggs & Stratton lawnmower
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
HALF OF AUGER NOT WORKING
When you got something caught in the auger, the shear-pin probably did it s job and broke, to save the gear box. Remove the old shear pin and install a new one
