20 Most Recent
Samsung SF-565PR/XST Printer Questions & Answers
Sir
my printer samsung sf-565pr show
Sounds like a paper jam check out the paper path going through machine. somewhere in there is some paper jamming a switch the cartridge is the printer head that holds the ink uinstall cartridge then reinstall . Then trace back what made it do this what happened the last time it worked. If nothing else go through the reinstallation process like you are hooking it up for the first time and that way you check all your cords make sure the paper tray is right and reload the driver and see , It is something simple one or all those things I mentioned.
12/4/2012 6:29:52 AM •
Samsung...
Answered
on Dec 04, 2012
I refilled my sf 565 pr machine, but after
First time
I am not clear what was toner refill your printer.
Other brand I mean hp/canon.It is not supported toner for samsung.Try first time clean drum.If it not fix may be change toner cartridge.
6/29/2012 7:26:43 AM •
Samsung...
Answered
on Jun 29, 2012
When tthe samsubg SF565pr printer shows non
each printer cartridge has several pages lifetime. if the cartridge is empty if u refill it the printer starts showing non samsung. but u can still print. if not printing at all replace the cartridge with original one.
8/25/2011 10:44:32 AM •
Samsung...
Answered
on Aug 25, 2011
LSU ERRORS DISPLAYED ON SAMSUNG
LSU ERROR on this machine means that the Laser Unit is fauly and needs to be replaced.
You can call for a tech or can take the printer to a printer service.
6/3/2011 10:56:54 AM •
Samsung...
Answered
on Jun 03, 2011
Low heat error for samsung
check the fuser heat lamp during initalize ,if heat lamp not glow then check the fuser thermostate
if open then replace the thermostate.
3/25/2011 6:58:52 AM •
Samsung...
Answered
on Mar 25, 2011
Paper jam
While working with your Samsung printer you may encounter a paper jam. Paper jams are usually obvious, but sometimes you may face a situation when there is no indication that the paper has jammed up the printer, in that case, open it up and visually inspect it to search for the jammed paper.
1/19/2011 4:44:45 AM •
Samsung...
Answered
on Jan 19, 2011
Toner exhausted
HI there make empty the used toner drum and try. Waiting for your reply.
1/7/2011 10:29:54 AM •
Samsung...
Answered
on Jan 07, 2011
