20 Most Recent
Krups XP7260 Espresso Machine Questions & Answers
Error code 06
Look for the leakage source:hoses, actuator, priming valve?
Switch or distributor switch control fault: incorrect detection of cams error in distributor position in cylinder descent phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
My Krups espresso 7260 is
if the machine is old it could be leaking due to lime/calcium build up limeaway and clr should fix the problem, if not you probably have a cracked hose inside
XP2280. Where can I obtain an owner's manual?
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page
View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
How do I fix error code 12
That is a very uncommon error code. It is not detecting the ejection switch pulse, it may be just a case of dismantling and cleaning and checking the switch operation. It's all internal so you need to remove the housings.
