20 Most Recent Adobe Photoshop 6.0 for PC Questions & Answers
2answers
How to erase the background?
right click on eraser and u would find magic eraser and remove it.
2/26/2022 2:23:28 PM • Adobe Photoshop... • Answered on Feb 26, 2022
2answers
Every time I try to
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
9/23/2019 5:16:35 PM • Adobe Photoshop... • Answered on Sep 23, 2019
Cannot get hyperlinks to work when emailing html file
Hi this is Alex Walker expert to fix this Issue Call me +1(518)348-9393 I will be glad to assist you
7/4/2017 12:06:05 AM • Adobe Photoshop... • Answered on Jul 04, 2017
Error number 0x80040303
You need authorization code/serial number. The authorization code/serial number comes with the software when you purchase it. It is usually included in a printed card or a sticker affixed to the case/box. Contact your seller if you did not receive it. You cannot use the software without it. If you lost the number, contact manufacturer support. You will need to provide proof of purchase.
8/6/2014 10:54:39 PM • Adobe Photoshop... • Answered on Aug 06, 2014
Won't open project
Hi there there is no problem The first things you do you need to Type %temp% on start run and hit enter it will drop you in Temp folder where you will find loss of unwanted files just delete them and then go one folder above that is windows then delete all temporary files in temp folder and prefetch files in prefetch folder . check if your project drive have enough space to cache or you can go to the preferences and change the cache folder and all should be cool .... if you face any issue please don't hesitate to ask me . if works my solution please grade me. regards Dushyant
6/30/2014 4:41:09 PM • Adobe Photoshop... • Answered on Jun 30, 2014
Errror 0x80040303 on installing photoshop cs
HI Good Evening To avoid this error close all adobe products running also from the task manager end all jobs related to adobe,Then run the setup and you will pass through. cheers :)
6/30/2014 3:35:03 PM • Adobe Photoshop... • Answered on Jun 30, 2014
New button in photoshop 6 freezes program
Hi There can you please explain your problem in detail like which button you are talking about.
6/30/2014 3:33:07 PM • Adobe Photoshop... • Answered on Jun 30, 2014
Downloaded photoshop 6.0. but when i open the file the error comes to contact pckware for licensing information
I think your software is not a license version. You can uninstall your photoshop from your pc then reset your pc and again install photoshop with serial key and registration in the Adobe web site. It will be solved
6/23/2014 8:51:48 AM • Adobe Photoshop... • Answered on Jun 23, 2014
2answers
What is a supported file type in Photoshop
photoshop will open any type of photo file. it will save it as a pdf or you can choose to save it as another file by the drop down menu when you click "save as"
9/20/2013 10:47:31 AM • Adobe Photoshop... • Answered on Sep 20, 2013
I can't scan from my printer to Adobe Photoshop
Do you have the Photoshop TWAIN plug-in? If not then you can use another scanning software for the image and save it in TIFF format. You can then open it with Photoshop. --- http://www.twain.org/
1/10/2012 12:19:32 AM • Adobe Photoshop... • Answered on Jan 10, 2012
How to down load photoshop6.0
DOWNLOAD IN THE SEANCE FROM CD TO COMPUTER or from web to your computerand its too old Photoshop 6 which will not be compatible with windows 7 or vista so it may give error regarding compatibility issue so please be clear for this and let me know the error you are getting when you download the software .Hope it helps youPlease vote for me Thanks and regardsDushyant
12/22/2011 10:27:44 AM • Adobe Photoshop... • Answered on Dec 22, 2011
Who is the developer of adobe ps 6.0 ?
Adobe is the developer of Photoshop.
8/8/2011 2:26:09 PM • Adobe Photoshop... • Answered on Aug 08, 2011
I hove got the error
Forget about installing Photoshop CS2 or CS3 or lower versions on Win 7, the software are not compatible with Win 7 OS. Get a newer version CS4 or higher.
You can check it @ Windows 7 Compatibility Center
Hope it helps.
9/26/2010 1:47:58 PM • Adobe Photoshop... • Answered on Sep 26, 2010
Adobe Photoshop Elements 6.0 (editor) stopped working...
It's most likely incompatible with your system. That's a very old version of Photoshop.
7/19/2010 7:28:30 PM • Adobe Photoshop... • Answered on Jul 19, 2010
Adobe Photoshop Elements 6.0 (editor) had stopped
Try a System restore
4/4/2010 12:14:01 AM • Adobe Photoshop... • Answered on Apr 04, 2010
Editor on Photoshop has stopped working!
dude try once by reinstalling your photoshop.
3/13/2010 7:47:59 PM • Adobe Photoshop... • Answered on Mar 13, 2010
Adobe Photoshop 6.0 for PC Logo
Popular Tags
50 questions posted
Top Adobe Computers & Internet Experts
David Shaub
Steve Nordquist
Steve Nordquist
George Etukudo
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Adobe Computers & Internet
Most Popular Question
error number 0x80040303
  • Computers & Internet
