20 Most Recent
Comfortmaker G8MXN1102120A 110,000 BTU 80% Gas Furnace, 1 Stage, Questions & Answers
Lp furnance ignites for 3seconds then shut off.
A pressure switch code means there is an unsafe condition that should be looked at by a competent service tech. Sometimes there is a switch failure, but most of the time there is an unsafe condition.
FURNACE WILL NOT LIGHT
If the combustion blower is working the next step in the process would be the pressure switch. Check for plugs in the drain lines or venting. If the pressure switch is working it could be the ignitor.
12/1/2013 3:43:51 PM •
Heating &...
Answered
on Dec 01, 2013
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
