20 Most Recent As Seen On TV Robo Sweeper Questions & Answers
Robo sweeper
ARE THEY CLOGGED AROUND WHEELS WITH HAIR ,AND TRY SOME W D FORTY OIL ,
4/10/2013 9:44:32 AM • As Seen On TV... • Answered on Apr 10, 2013
Repair or cleaning of Hyla EST Vacuum Cleaner.
This is not a make that we known in North America. It is also VERY unusual as they use a wet filter. https://www.google.com/search?q=Hyla+EST+Repair+or+cleaning
4/26/2024 12:22:50 AM • Vacuums • Answered 10 hours ago
How do I get the attachment for cleaning windows to stay on to the steamer
That would depend on the make and model of the steamer.
4/18/2024 8:28:28 PM • Vacuums • Answered on Apr 18, 2024
2answers
Model E130J how do I shut off the led service life on my Aerus CentraLux central vacuum? I have replaced the motor and light stays on. The blue box on the circuit board had the switch ON and MEDI.
To turn off the LED service light on your Aerus CentraLux central vacuum model E130J after replacing the motor, switch the blue box on the circuit board from "ON" to "MEDI."
4/6/2024 1:06:59 PM • Vacuums • Answered on Apr 06, 2024
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM • Vacuums • Answered on Mar 31, 2024
Do you have service center here in Bacoor, Cavite? Thanks
We don't have any service centres at all! We are Fixya dot com. We are a peer to peer self help group. We don't sell anything, we only provide free information. Here are a few service centres in Bacor. If you need further help, click Comment under my answer. Let me know 'make model (what it is)'. https://www.google.com/search?q=Bacoor%2C+Cavite+service+centre ..
3/30/2024 1:43:53 AM • Vacuums • Answered on Mar 30, 2024
Electrolux Ergorapido EHVS2510AW. The blue light stays on?
Question edited for a lot more clarity. It indicates that it is charging. https://www.google.com/search?q=Electrolux+Ergorapido+EHVS2510AW.+The+blue+light+stays+on ..
3/26/2024 3:24:04 AM • Vacuums • Answered on Mar 26, 2024
How to empty a etl vc-h3301 vacuum cleaner
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
3/21/2024 4:57:04 PM • Vacuums • Answered on Mar 21, 2024
What distinguishes Singhal Industries' biohazard plastic bags?
Singhal Industries produces biohazard plastic bags with high-quality materials and stringent manufacturing standards to ensure durability and containment of hazardous materials. Their bags are specifically designed to meet industry regulations and ensure safe disposal practices.
3/13/2024 6:51:51 AM • Vacuums • Answered on Mar 13, 2024
2answers
Pops open when bag still almost empty
try cleaning the filters if they are blocked then suction is lost and would appear like bag was full. hope this helps
3/9/2024 1:34:57 AM • Vacuums • Answered on Mar 09, 2024
My daughter has an ONN WA 230 cube radio alarm clo...
press time\alarm button three times for min hand and again for hour
2/10/2024 2:27:36 PM • Vacuums • Answered on Feb 10, 2024
How can i fix the spring loaded cover on a Miele
Hi the lid on my miele where tools go isn't latching how do I fix it plz
2/7/2024 6:12:28 AM • Vacuums • Answered on Feb 07, 2024
2answers
Kenmore Beltless Vacuum brush will not spin.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
2/3/2024 5:49:33 PM • Vacuums • Answered on Feb 03, 2024
Red light comes on after charging my ergorapido
I had the same problem. Red light would come on after charging was complete. On investigation I found that there is a small gray wire that runs from the rear batteries to a large solder spot on the control board. Upon re-soldering this wire I got an additional 3 V of power and the red light does not come on anymore after it is charged. I can vacuum the whole house and then some and still not run the batteries down.
2/3/2024 6:53:13 AM • Vacuums • Answered on Feb 03, 2024
When I plug in my vacuum it has no power. I checked everything possible but when I touch the hose switch and the whole machine turns on. What is the cause of this issue please?
Question edited to add CAPS, sentences and punctuation! All questions need full 'make model (what it is) first 3 words. The likely reason is a bad connection, or it is supposed to turn on with the 'hose switch'. Google make model manual ..
1/28/2024 2:49:04 AM • Vacuums • Answered on Jan 28, 2024
Rug doctor make a noise then it started smoking and water was coming out of it
Sounds like the seal split. Strip it down, clean, replace the motor and seals.
1/25/2024 7:22:03 AM • Vacuums • Answered on Jan 25, 2024
As Seen On TV Robo Sweeper Logo
1 questions posted
Top As Seen On TV Vacuums Experts
john h
Are you an As Seen On TV Vacuum Expert? Answer questions, earn points and help others
View Most Popular
  • As Seen On TV Vacuums
Most Popular Question
robo sweeper
  • Vacuums
