20 Most Recent Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity Washing Questions & Answers
What's causing the wash cycle selection knob to not turn to the selection I want?
The water selection switch is bad, it is separate from the board.
2/5/2018 4:02:12 PM • Kenmore HE2 Plus... • Answered on Feb 05, 2018
What does error f-30 mean
find the interpretation of it in the owner's / user's manual . thanks.
3/4/2016 3:22:45 AM • Kenmore HE2 Plus... • Answered on Mar 04, 2016
How do I fix a plugged drain on a HE2 plus Kenmore washer.
This is a generic type answer, but, most of these washers have a pump to pump out the water. If some small thing like a hairpin gets in there it will collect lint and plug the outlet of the pump. Or the impeller to the pump may break. Access the pump, remove it, and look for the problem there. Make sure the belt drive to it is working or it will pump no water. I hope this helps. I assume you meant by "plugged drain", that no water is getting pumped out. I have seen this problem in Kenmore washers in the past.
12/15/2015 2:15:25 AM • Kenmore HE2 Plus... • Answered on Dec 15, 2015
What is meaning of error code f33?
11/29/2015 10:28:32 PM • Kenmore HE2 Plus... • Answered on Nov 29, 2015
I cleaned out filter still would not drain n I still get f21?
Unfortunately, that usually means that the pump needs to be replaced. Open the washer again and look inside the pump area. Check if the impeller can move freely and is mounted on its shaft. If there is anything blocking the impeller, then remove the object and try again. Also check if the pressure switch tubing is clear. Remove the top of the washer and look near the back of the unit. You should see a tube attached to the switch. Remove the tube and blow through it. Check the ball valve for the drain for any foreign objects; this is just after the pump and before the drain hose. If there was anything blocking these parts, test the washer cycle again. Check the wiring for the pressure switch and the CCU. If there were no blockages and the drain pump impeller moved freely, replace the drain pump. I hope this helps. Cindy Wells
7/25/2015 9:53:45 PM • Kenmore HE2 Plus... • Answered on Jul 25, 2015
I receive a PF error message every time I use the timed cycle
PF = Power failure
2/13/2015 8:49:26 AM • Kenmore HE2 Plus... • Answered on Feb 13, 2015
Resetting a F 01 error repair.
F 01 is a bad control board, you dont reset, replace board
1/1/2015 6:45:18 PM • Kenmore HE2 Plus... • Answered on Jan 01, 2015
How do I reset a F 01 error
F01 indicates a failed electronic control board. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging, then the electronic control board will need to be replaced.
12/2/2014 10:06:48 PM • Kenmore HE2 Plus... • Answered on Dec 02, 2014
Start button broken
The start button is a removable and replaceable part. Order it on line to save money.
5/22/2014 1:10:17 AM • Kenmore HE2 Plus... • Answered on May 22, 2014
2answers
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
4/23/2024 11:52:33 AM • Kenmore Dryers • Answered 2 days ago
2answers
Trying to find out how much part #7 on the exploded view of the Kenmore elite electric dryer model 110.2808 is? It is a motor.
110.2808 is an incomplete model number. Motors are typically $140 to $180 USD https://www.easyapplianceparts.ca/PartInfo.aspx?inventory=334304&SourceCode=18 This is is a typical Kenmore model designation and is probably the matching washer to your dryer. Yours is missing 4 numbers. Label in the back, label on the door frame, mentioned on the manual.
Model # 11028081700 Official Kenmore Elite washer
https://www.google.com/search?q=Kenmore+elite+electric+dryer+110.2808 ..
2/23/2024 6:44:28 PM • Kenmore Dryers • Answered on Feb 23, 2024
Is it possible to reverse the direction that the door opens on Kenmore Elite Quietpak 4?
Yes, it looks like you can. Don't forget though that you have to get inside and move the door switch. https://www.google.com/search?q=Kenmore+Elite+Quietpak+4+reverse+door ..
1/26/2024 12:16:00 AM • Kenmore Dryers • Answered on Jan 26, 2024
Kenmore ELE-2406028 Laundry Dryer. Help with door switch replacement.
It is an easy enough job. The videos show how. The parts are here https://www.google.com/search?q=Kenmore+ELE-2406028+door+switch ..
1/2/2024 4:11:27 AM • Kenmore Dryers • Answered on Jan 02, 2024
8546206 tech sheet
What is the question? Do I have the tech sheet? Yes I do.
12/17/2023 6:48:07 PM • Kenmore Dryers • Answered on Dec 17, 2023
Looking for age of Kenmore gas dryer Model 110.77741600
The are various idea here.
I have model and serial #s for my washer/dryer. What year ...
iFixit https://www.ifixit.com > Answers > View > I+have+m... Apr 3, 2017 - I have a Kenmore washer and dryer. I have the model #s and serial numbers. I need to know what year ( how old are my appliances?) of the models. 4 answers · Top answer: Erin Morrissey , How to find out the manufacture date of a Kenmore washer or dryer by the ... How old is my dryer? - Kenmore 110 Series ... 2 answers Mar 11, 2022 How old is my kenmore washer/dryer combo? - iFixit 2 answers Aug 4, 2018 help me find out how old this washer is - iFixit 2 answers Sep 29, 2021 What is this dryer model number? - Kenmore Elite ... 2 answers Jul 18, 2016 More results from www.ifixit.com Missing: 110.77741600 ‎' Show results with: 110.77741600
Can you tell me the age of a dryer from the model or serial
JustAnswer https://www.justanswer.com > Appliance Repair May 19, 2023 - Can you tell me the age of a dryer from the model or serial # Kenmore 600. Model is 110 78652700 serial is - Answered by a verified ... 1 answer · Top answer: Good afternoon. My name is ***** ***** I'll be assisting you with your appliance today. Please ... Missing: 110.77741600 ‎' Show results with: 110.77741600
12/15/2023 2:51:24 AM • Kenmore Dryers • Answered on Dec 15, 2023
2answers
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity Washing Logo
21 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
cleaned out filter still not drain n
  • Dryers
