20 Most Recent Stoves 23 in. 600GRC Gas Cooktop Questions & Answers
The large burner on stove keeps clicking away on
The ignitor switch for that burner is bad. It is located behind the control knob for that burner.
1/13/2011 1:35:33 AM • Stoves 23 in.... • Answered on Jan 13, 2011
After cleaning the gas top
Igniters got wet.Look for the crack igniters or replace module control.
1/9/2011 7:26:25 PM • Stoves 23 in.... • Answered on Jan 09, 2011
All 4 igniters are constantly on the only way to
This is usually caused by water getting to an igniter switch during cleaning, or from a boil over / spill. Disconnect power and let it dry out. It may take a few hours or a day, but should be fine after it has had a chance to dry out.
12/26/2010 4:04:59 PM • Stoves 23 in.... • Answered on Dec 26, 2010
One of my burners is only giving a tiny amount of gas
Get a needle, and put it through every one of the small holes where the gas comes out. If that doesnt work you should be able to just lift the burner off gas line and check to see if it is clogged with anyting. I once found a dead bettle blocking the gas line....
1/22/2008 9:13:53 PM • Stoves 23 in.... • Answered on Jan 22, 2008
Broken knob on cookwell 2 burner hot
found new knob to suit thank you
11/8/2009 9:30:21 AM • Stoves Cooktops • Answered on Nov 08, 2009
Cnverting from l.p to nat. gas
Most times you have to unscrew the hex nut on top of the regulator (right where the gas line connects) and flip the plunger inside. It usually shows LP on one side and NAT on the other.
10/1/2008 1:24:09 AM • Stoves Cooktops • Answered on Oct 01, 2008
My defy slimline cooktop shows ER42 but I changed the capacitors, what is wrong?
The ER42 error code typically indicates an issue related to insufficient power being delivered to the ceramic element. Check Power Supply: Ensure that the cooktop is receiving adequate power. Verify that the power supply is stable and not fluctuating. Inspect the PCB (Printed Circuit Board): Since the error points to a fault on the PCB, visually inspect the control board for any signs of damage, loose connections, or burnt components. Capacitors: You mentioned that you've already changed the capacitors. While this is a good step, it's essential to ensure that the new capacitors are correctly installed with the same rating and polarity. Reset the Cooktop: Turn off the power to the cooktop completely. Disconnect it from the mains for a few minutes, then reconnect it and power it back on. Sometimes, a reset can clear minor glitches. No joy? Consider professional repair.
4/21/2024 5:08:45 PM • Cooktops • Answered on Apr 21, 2024
I can't lower the heat on my Whirlpool electric stove cooktop. Started about a month ago. Stove is 15 yrs old. Everything else on the stove works e
It needs a new control if it has dials or a control pad or a part if it is electronic. Full make and MODEL (what it is) in all answer please as first 3 words in every question.Edited as model number given Whirlpool GFE471LVShttps://www.whirlpool.com/owners-center-pdp.GFE471LVS.htmlThe Infinite Switches are $130, so it is best to test them with a multimeter first.https://www.partswarehouse.com/Whirlpool-GFE471LVS0-Freestanding-Electric-Range-s/131742.htmVideos showing how to changehttps://www.google.com/search?q=whirlpool+gfe471lvs+replace+hob+infinite+switchOwner Manual, just because it was therehttps://www.manualslib.com/products/Whirlpool-Gfe471lvs0-10479409.html..
4/6/2024 6:50:10 PM • Cooktops • Answered on Apr 06, 2024
On my induction hob, 2 discs on the right side stopped working at the same time, I put the pan on and it shows as if it hadn't been detected, the same pan works on the remaining 2 discs on the left
A) https://hobguide.com/induction-hob-cannot-detect-pan/ B) https://hobguide.com/induction-hob-not-working-on-one-side/ You are advised to not try to get into the electronics of the induction hob. Such is dangerous. The unit uses 3 phase electricity, something unlikely to be addressed by DIY activity if you want to be safe. Check your warranty. I assume this is not a matter of pans of the wrong material or size being deployed. This well may require a technician to sort out. The brand/model has not been identified so I cannot direct you to further resources. Your user manual surely provides a company name where you might seek some customer support.
10/6/2023 9:36:18 PM • Cooktops • Answered on Oct 06, 2023
How do i remove a venturi from a cooktop
There seems to be quite a few ways... Check out these sites.. https://www.google.com/search?q=How+can+i+remove+a+stuck+venturi Best to you.
6/30/2023 3:26:43 PM • Cooktops • Answered on Jun 30, 2023
Jenn Air C221 element only goes to high?
Based on the symptoms described, it is possible that the issue lies with the ceramic element that the burners connect to at the back of the burner unit. This could be causing a short circuit between the two burners, which is preventing the large burner from being adjusted lower when both burners are on. It is also possible that there is an issue with the wiring or connections between the two burners, which is causing a similar short circuit. However, given that the smaller burner appears to be working fine, this seems less likely. Another potential cause of this issue could be a problem with the control board or another component of the stove's electrical system. However, given that replacing the infinite switch and receptacle for the large burner did not resolve the issue, it seems less likely that this is the root cause. In order to determine the exact cause of this issue, it may be necessary to consult with a professional appliance repair technician who can diagnose and repair the stove.
6/21/2023 9:17:30 PM • Cooktops • Answered on Jun 21, 2023
Domain ceramic cooktop cec70 will not turn off
If your ceramic cooktop model CEC70 is not turning off, there are a few steps you can take to troubleshoot the issue: 1. Check the controls: Ensure that you have properly followed the instructions to turn off the cooktop. Some models may require you to press and hold a specific button or combination of buttons to power off the cooktop. Refer to the user manual for your specific model for detailed instructions on turning it off. 2. Power cycling: Try power cycling the cooktop by turning off the power at the circuit breaker or unplugging it from the power source. Leave it unplugged or with the power off for a few minutes before plugging it back in or turning the power back on. This can sometimes help reset the controls and resolve any temporary issues. 3. Control lock: Check if the cooktop has a control lock feature that might be activated. Some models have a lock function to prevent accidental changes to the settings. Look for a button or key combination that activates or deactivates the control lock. Refer to the user manual for instructions specific to your model. 4. Contact customer support: If the issue persists, it is recommended to reach out to the manufacturer's customer support or consult a professional technician who specializes in appliance repairs. They will be able to provide further guidance or arrange for a service visit to diagnose and fix the problem. Remember, when dealing with electrical appliances, it's always important to prioritize safety. If you encounter any unusual or potentially hazardous situations, such as smoke, sparks, or strong odors, immediately turn off the power supply and contact a professional technician for assistance.
6/19/2023 9:27:30 AM • Cooktops • Answered on Jun 19, 2023
Can anyone tell me the specs I would need in a varistor to replace the one from my Iwatani induction cooktop?
o determine the specifications for the varistor to replace the one on your Iwatani induction cooktop, you will need to know the voltage rating and the maximum current the varistor can handle. One way to determine these specifications is to check the datasheet for the original varistor, which may be available from Iwatani or the varistor manufacturer. If you cannot find the datasheet, you can try measuring the resistance of the varistor with a multimeter, which can give you an idea of the voltage rating. However, keep in mind that the resistance may change as the varistor ages or if it has already failed. Additionally, you may need to know the peak current that the varistor can handle. This information may be available on the datasheet or on the original varistor if there are any markings left. If you cannot determine the peak current, a general rule of thumb is to choose a varistor with a maximum surge current rating that is higher than the maximum current that the circuit can deliver. It's important to choose a varistor with the correct voltage rating and peak current handling capability, as using an incorrect varistor can potentially cause further damage to your induction cooktop or pose a safety hazard
4/23/2023 7:33:25 AM • Cooktops • Answered on Apr 23, 2023
Can I remove the downdraft equipment under my jennair electric cooktop and still use my cooktop?
It is possible to remove the downdraft equipment from underneath your JennAir electric cooktop and still use the cooktop, but it depends on how the downdraft equipment is attached to the cooktop and whether there are any other issues that may arise from removing it. Before attempting to remove the downdraft equipment, you should consult the user manual or contact JennAir customer service to ensure that it is safe to do so and to obtain any specific instructions for your particular model. Some potential issues to consider when removing the downdraft equipment include:
  1. Airflow: The downdraft equipment is designed to help draw smoke, steam, and odors down and out of the kitchen. Without it, you may experience reduced airflow and ventilation, which could result in lingering odors or smoke.
  2. Heat distribution: The downdraft equipment may also help distribute heat evenly across the cooktop surface. Without it, you may experience hot spots or uneven cooking.
  3. Stability: The downdraft equipment may provide additional support or stability to the cooktop. If it is removed, the cooktop may become less stable or secure.
If you decide to proceed with removing the downdraft equipment, it's important to follow all instructions carefully and to take appropriate safety precautions. You should also be prepared to address any issues that may arise as a result of the removal, such as by using an alternative ventilation system or adjusting your cooking techniques to compensate for any changes in heat distribution. If you're unsure about whether or how to remove the downdraft equipment from your JennAir electric cooktop, it's best to consult with a professional technician or contact JennAir customer service for guidance.
4/23/2023 7:29:19 AM • Cooktops • Answered on Apr 23, 2023
My Defy Slimline hob show error 22 and wont switch on
Error code 22 on a Defy Slimline hob usually indicates an issue with the touch control panel or power supply. Here are a few steps you can try to resolve the issue:
  1. Turn off the power to the hob at the circuit breaker for a few minutes, and then turn it back on. This can reset the electronics in the hob and clear the error.
  2. Check the hob's power supply. Make sure the hob is getting power from the electrical outlet or circuit breaker. If the hob is plugged in, try plugging it into a different outlet or resetting the circuit breaker.
  3. Check the touch control panel. Sometimes, the error code can be caused by a problem with the touch control panel. Make sure the panel is clean and free of debris or moisture. If the panel is damaged, it may need to be replaced.
  4. Contact a qualified technician. If the above steps don't resolve the issue, it may be a more serious problem with the hob's electronics or power supply. Contact a qualified technician or the manufacturer for further assistance.
4/23/2023 7:27:33 AM • Cooktops • Answered on Apr 23, 2023
Stoves 23 in. 600GRC Gas Cooktop Logo
5 questions posted
Top Stoves Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Stoves Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Stoves Cooktops
  • Stoves Cooktops
Most Popular Question
large burner stove keeps clicking away
  • Cooktops
