20 Most Recent
Sovereign ARP-1000E Air Conditioner Questions & Answers
Shuts off and light blinks
Check the wter tank it must be full and needs emptied before the unit will continue to run. If your runnig a drain hose, then the hose may be plugged or the float switch for the bucket is either hung up or malfunctioning.
If this was helpful a vote with the thumbs up would be greatly appreciated for the free advice.
Thanks and if you need more let me know.
8/23/2011 7:09:32 AM •
Sovereign...
Answered
on Aug 23, 2011
Water keeps on spilling out
The drain plug for draining accumulated water is located on the back of the unit's lower left side (as you're facing the back just to the left of the cord keeper. Unplug it, disconnect the exhaust hose and roll it to a drainage area. Unscrew the plug and let it drain. Securely replace the drain plug when draining is complete.
Hope this helped you.
6/9/2011 1:13:41 AM •
Sovereign...
Answered
on Jun 09, 2011
Water full
Your not saying what brand or model you have but it sounds like you don't have the right drain system
7/24/2011 1:44:24 PM •
Sovereign...
Answered
on Jul 24, 2011
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
