20 Most Recent
Delta PLC Load Cell Module DVP02LC-SL DVP02LCSL Questions & Answers
How do you remove a Delta Towel Rod
To remove a Delta towel rod from the wall, you will need to first locate the mounting brackets that hold the rod in place. These will typically be located at each end of the rod, and will be secured to the wall with screws. Here are the steps to remove the towel rod:
- Gather the tools you will need, including a screwdriver or drill with screwdriver bit.
- Locate the mounting brackets at each end of the towel rod.
- Using the screwdriver or drill, remove the screws that secure the brackets to the wall.
- Carefully lift the towel rod off of the brackets and set it aside.
- If the mounting brackets are not reusable or you do not plan to reuse them, you can remove them from the wall by removing any remaining screws.
How do these points equate to money?
No money ever!
There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun.
ADMIN Andrew
- Answers: 65,820 and not a penny per Answer.
Head over to
www.justanswer.com they pay lots of money because they charge for people to ask a question.
