20 Most Recent
Dodge 2003 Grand Caravan Sport Questions & Answers
Brake problem whats causing or what part
that leaves
an internal booster issue or non return valve faulty to the vacuum line
if you are sure the brake master cylinder is not bypassing internally at the cups
cant be anything else
no air in the lines
and all calipers and brakes replaced
should not have that prolem
Brake light is on
Low brake fluid or park pedal slightly applied would be the most common problem. If brake fluid is low, have the brakes checked. It is not a good idea to add brake fluid unless there is a leak as the extra fluid will only spill out when the brakes are replaced.
Where is the blower resistor located
behind the glovebox door. You have to remove the glovebox or at least tilt it out of the way, then just unscrew the resistor and unplug it and put the new one in.
How do i by pass a pinhole leak in the steel tubing on the rear heater core ?
There are always 2 hose connections going to the heater in the vehicle.. One brings the water into the heater and other takes the water back out.. They are usually on the firewall in the engine compartment, and on the same side as where the heater will be inside the vehicle, under the dashboard..
Did you bypass both of them?
1994 dodge spirit. Shifted cable
The shift cable on a 1994 Dodge Spirit connects the gear shift lever to the transmission, allowing the driver to shift gears. If the cable is damaged or worn out, it may need to be replaced. Here are the general steps to change the shift cable on a 1994 Dodge Spirit:
- Park the car on a level surface and set the parking brake.
- Locate the shift cable where it connects to the transmission. It will be on the driver's side of the vehicle, near the front of the transmission.
- Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the transmission.
- Trace the cable up to the gear shift lever inside the vehicle.
- Remove any trim pieces or panels that are blocking access to the cable connection at the gear shift lever.
- Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the gear shift lever.
- Remove the old shift cable from the vehicle.
- Install the new shift cable by first attaching it to the gear shift lever and then connecting it to the transmission.
- Secure the cable to the gear shift lever and transmission using the retaining clip or nut that you removed earlier.
- Test the new shift cable by shifting through all of the gears to ensure that it is functioning properly.
- Replace any trim pieces or panels that you removed earlier.
Serpintine belt on 2000 dodge caravan needs attaching
I take it you mean installed. The belt sequence for the pulleys should be on the cross member under the hood over the radiator or somewhere in that vicinity. Follow that pattern and you will have to put a ratchet in the front og the belt tensioner to turn it down far enough to get the belt the rest of the way on. Go to youtube and do a search on how to do it. Someone will have a video showing how to do it.
